Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 08-09-05, 10:25 AM   #1
swingkid02
HELP!!! Power Windows/Locks Passenger Side
I have a 97 Integra GS-R and the windows and power door locks and even the side view mirror on the passenger side do not work. I have checked the fuses and they all seem to be in order. I'm assuming it's an electrical problem but am not sure as to where to fix it from.
I'd really appreciate any help possible with this.
Thanks again,
Rob
      Registered and logged-in users don't see this ad!
Register your free account today.
swingkid02 is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-10-05, 12:57 AM   #2
4drman
Takes more than patience.
Send a message via AIM to 4drman
well, i know the power to the lock, window and right speaker are coming from a bundle of wires underneath ur glove compartment up in the dash, they should lead to inside the side of ur car and thru the door thru a plastic wire protector, get ur head up under there and check for any loose wires, signs of anything out of the ordinary.
if u find no visible problems, find a way to get a charge to the wire, first disconnect it completely from any parts and run a small amount of power and test the voltage at the other end , if the voltage meter doesnt go up, youll know there is something wrong between point a and point b. if it does go on, check ur motors and connections. from there on i cant help ya, how to do it is beyond me but im sure it would work for diagnosing the problem, dont be satisfied with one opinion tho.
good luck
-julian
4drman is offline   Reply With Quote
Old 08-19-05, 10:01 AM   #3
Altern8r
Altern8r's Avatar
you could take the protector between the car body and door between the hinds out and check the wires there to see if one of them has broken and maybe you can solder them together again.
Altern8r is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
