Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Prev Previous Post   Next Post Next
Old 02-18-05, 12:04 AM   #1
hob684
Send a message via AIM to hob684 Send a message via Yahoo to hob684
Seafoam writeup <56k Beware>
Ok. I wanted to see what the whole big deal about Seafoam was so i went and bought 2 bottles @ ~$4 each.
Step 1: Went home to change the oil.
The engine (NA y8 w/ ~90k) was still pretty warm so i let it cool for a bit.
I first put about a 1/3 bottle in the crank:
Step 2: I disconnected my brake booster line and SLOWLY :!: poured in the remaining 2/3 bottle WITH the car running. Sometimes it would sputter and start to die but just slow down the pouring and it'll catch back up. *Some smoking may occur*
This is the line i used.
Step 3: i poured the other bottle into my gas w/ about a 1/2 tank. Yes i know this is too much. I believe this was a reason why i was running hot the other night when i was just sitting around ina parking lot w/ my car running. Not TOO hot.. but warmer than normal.. about 2/3 up the gauge.
Now this is where i think i messed up. The bottle says to let it sit "OFF" for about 5-10 min. I didn't do this. *i did rev a bit while i was Seafoaming through the brake booster. This was all the smoke i got....
I then went for a "spirited" drive down my road.
No huge smoke clouds, no problems... It seemed to run a bit smoother and a bit quieter..
I"ve heard that Seafoaming will foul your plugs... so i pulled all of mine and checked. No different than normal. All 4 looked the same.. *i cleaned 'em w/ carb cleaner anyways..
I returned from about a 15min. drive and changed the oil. Then refilled w/ Castrol GTX StartUp 10w40.
All Done!
This is the next Seafoam Project to go under. 1985 Toyota pickup w/ 256k original miles on the odo. I'm gonna do this on spring break. I'm trying to find gaskets for valvecover and a cheap ass headgasket b/c i'm gonna pull all of em before and after and see how well this stuff works.
i'm not scared of f'in this engine up. It runs but no insurance on it b/c its jsut a "work" truck. As you can tell by the flat tires it really sees alot of "work"
Thats all for now.. sorry for the book
      Registered and logged-in users don't see this ad!
Register your free account today.
hob684 is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
