Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 02-16-05, 09:14 PM   #1
fac90
4th Generation Accord Main Relay Replacement
The main relay will need replacement. Right now its still winter, so it doesn't act up. But by this summer, it will give a lot of no start problems.
Where exactly is it located under the dashboard and is it difficult to replace?
I know you 4th generation owners definitely have been frustrated by this condition.
Thanks.
      Registered and logged-in users don't see this ad!
Register your free account today.
fac90 is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 02-27-05, 02:44 PM   #2
RonRay
RonRay's Avatar
PGM-FI Relay
This is a big problem with some of the other models too!
Below is the info on a CRX, but relates to all models with this type relay.
There are solder joints in the Main (fuel) Relay that crack and cause problems starting. At first, it seems to fail after running a short time (usually when re-fueling, making a quick stop etc.), or after it has warmed up. This will continue sporadically until later on, then it will fail completely.
Take the main Relay out from under the dash (usually near the fuse box), and pry the black plastic cap away from the under-side (plug) of the relay.
Look at the solder joints carefully with a magnifying glass and you will probably see a tiny circular crack around one of the joints.
Re-solder that joint (and any other joints that you suspect).
This should stop all your problems.
(Use these links to see larger images of the above)
Relay: http://uploadhut.com/view.php/28656.jpg
Clips: http://uploadhut.com/view.php/28658.jpg
Dry Joint: http://uploadhut.com/view.php/28653.jpg
"Only an egotistical fool would be so arrogant as to quote himself" ~ RonRay 2005
RonRay is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
