| Do It Yourself This is where you will find step by step instructions so you can Do it Yourself! |
Thread Tools | Display Modes |
#1 | |||||||
Alternator and coolant check
| Sponsored Links | ||
#2 |
That thing is a hydrometer, it measures specific gravity. That tells you the strength of the antifreeze, as far as what temperature it'll freeze. It tells you ABSOLUTELY NOTHING about whether the anti-corrosion chemicals are used up. The brown color tells you that you should've changed your antifreeze a long time ago.
Check your battery again (engine off) & turn on the lights & blowers & stuff. It shouldn't drop much below 12v. Now run the engine, check the voltage at the battery. Running, it should be about 14 or 14.5v. Turn on all the electrical stuff you can, it should still stay about the same. This checks the alternator.
JimBlake '03 Accord, '07 Civic '01 Saab 9³, '05 9²x |
#3 |
Yeah, brown antifreeze doesnt sound good. Do a coolant flush ASAP. Before you cause further damage to the entire system due to corrosion and rust.
Why is it that you are testing these things? |
#4 | |
Quote:
#5 |
I check the battery 3 or 4 times a year, especially beginning of winter. I also check the water level & specific gravity in the battery. Add distilled water if needed. If the specific gravity of the 6 cells start getting different from one another, that's an early warning that the battery is not gonna last too much longer.
#6 |
How much of this antifreeze do I have to pour into the bucket. It's a gallon of antifreeze, so do I pure half of the bottle into a bucket. And then fill up the other half with water? And is it necessary to take of the thermostat off while doing this?
#7 |
You gotta fill up the radiator first, and make sure you have the bleeding valve open. The tank you fill up like halfway, there's a MAX line there. After you drive it for the first time, once it gets cool, go back and check the radiator and tank to make sure levels are still good.
#8 | |
Quote:
#9 | |
Still here... sorta...
Quote:
![]() You can easily go to any local auto parts store and they will test your alternator for free without you having to remove anything from the car. hih
2008 Lexus IS 350 - Starfire White 1999 Ford Explorer 4x4 Sport View My Feedbacks & ADD TO THEM!!! |
#10 | |
Quote:
#11 |
I don't know the total coolant volume for that car. Got an owner's manual? It's in there. Probably less than 2 gallons.
When you drain the coolant, it never ALL comes out. Even with the block drain plug... If you make up a 50/50 mix & add that, you end up too weak because of the water that's left in the system when you drain it. So I do a little math(!) & figure out what's 1/2 of the total coolant volume. After draining/rinsing/draining however many time I want, now what's left in there is just distilled water. I add the anti-freeze, whatever is 1/2 the total volume. Then I add more distilled water & bleed the air out. When I fill the reservoir, I just eyeball a 50/50 mix. After driving a few times that stuff will all become well-mixed. Try your best to get all the air out of the reservoir & fill to the very top. Then fill the reservoir between min & max. If you leave any air in the radiator, you have to hope it works its way out thru the reservoir.
#12 |
When you do the flush you don't have to remove the thermo. What I do, is that with the engine cold, remove the top hose from the radiator, and aim it downward into a bucket (It's illegal to dispose of coolant on the ground I think) and then start the car, and feed a hose right into the radiator once the car hits temp and opens the thermostat. It'll keep keep water running through the system. (use a radiator flush solution sold in stores. You drain radiator, fill with solution and water, let car run for about 10 minutes warm) then at that point just do the flush with a hose. When you see that the water comming out of the hose is comming out clean fresh water, turn off car, turn off hose, drain radiator, connect hose, and fill with the coolant. There's still water in the system. I don't know how much it will take, but if you need more, then add water to top off. put 50/50 in the resevoir.
PS. Don't forget to open bleed when doing final fill, have your heater on high when the car is running, and to check your levels after the frist drive. |
#13 |
I just read what I wrote, and it sounds like too many hoses. I'm also talking about using your garden hose, not only the radiator hose.
#14 | |
Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
