| Do It Yourself This is where you will find step by step instructions so you can Do it Yourself! |
Thread Tools | Display Modes |
#1 | |||||||
^ Visual Learner
custom shift light question?
| Sponsored Links | ||
#2 |
you need to create a circuit board with a DOT/Bar Display Driver(an actual semiconductor chip) that senses A/C voltage for the leds. this would need to be hooked up to your tach wire(which works on A/C voltage, the higher the voltage, the higher the RPMs are). it would probably be cheaper and easier to buy one off the shelf rather then create your own.
#3 | |
^ Visual Learner
Quote:
#4 |
to get an idea, take a look at this custom air/fuel meter:
http://www.scirocco.org/tech/misc/afgauge/af.html |
#5 |
^ Visual Learner
thanks....kinda confused now though.
#6 |
STOCK EJ8 noob
when u get ur shift light installed please post a pic i would be interested in seeing that
-= 1998 CIVIC EX =- -= SOHC D16Y8 =- current mods : 17inch alloys, AEM CAI, Greddy Evo2 system, alpine speakers all around, red/clear tail lights, projector headlights. dreams: auto to manual conversion |
#7 | |
^ Visual Learner
Quote:
#8 |
I was thinking about replacing a shift light for my dash dimmer nob on my 94LS. It seems to be a good place that would look like it was ment to be there
#9 |
the basic idea is that you have a chip(driver chip) that gets a signal from a wire(tach wire). when that chip detects a certain A/C Voltage(thats what the tach wire sends) it turns on a corresponding LED. sorry i could not be any more specific but I have never had to build one of these. the hardest part should be getting the chip(one that reads A/C voltage) and programming it. you need to know the A/C voltage output at specific RPMs to correctly program the chip. if you look online for "semiconductor chip" and your city name you may find some places that you could call to see if they offer a LED driver chip that takes A/C voltage as an input.
98 Adriatic Blue Integra LS Sedan 01 Electron Blue Prelude Base 00 Anthracite Metallic Civic EX |
#10 |
btw, like I suggested before, it may be easier to buy a off the shelf shift kit and installing that, unless you want to learn how to make them.
#11 |
it's sarcastic dude
^ that is good advice.
Another idea is to have a voltage comparator checking the alternators output, my friend created something very much like what you're describing with that as the input. Higher RPM's => higher voltage, but this is coming second hand. |
#12 |
٩(̾●̮̮̃̾•̃̾)۶
You could probobly have the needle of the tachometer hit small switches as it gets to the desired rpms..Like have the power wire run along the bottom of the needle then have contacts for each different LED where the needle would hit the rpms and the lights. That would be a much easier and kinda ghetto way of rigging it. Forgive me if you don't get what I'm saying, I'm tired.
1997 Subaru Legacy 2.5 GTWhat Am I Listening To? Never Forget 10/23/07 ٩(̾●̮̮̃̾•̃̾)۶
#13 |
sounds kinda neat. id like to see some pics.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
