Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 02-11-05, 02:00 PM   #1
DaNnYsEvEn
ThInK PiNk!
DaNnYsEvEn's Avatar
Send a message via AIM to DaNnYsEvEn
DIY 95 accord. clean out your dirty A$$ window switches (picz)
most people think a window switch has gone bad just because the window wont roll up anymore when you tap the switch. in most cases a simple cleaning will do the trick (rather than having to go and buy a new master switch for 50 bucks on ebay!). in this diy i did it on the master switch on my 1995 honda accord ex 4 door.
disclaimer: i am not responsible for anything that happens to your car if you try this.
1. first screw out the screw thats inside the lil coin holder thing.
2. pry out the master switch from the side making sure you dont snap it in half (this is kinda tricky)
3. disconnect the green switch.(used for power mirrors)
4. disconnect the grey switch.(used for the power locks and windows) and the brown switch thats right above it.
5. after you have done that the master switch should be out without any wires attached to it. now turn the master switch around and there are 3 screws to take out.
6. after you do that the whole switch system should come out and should look like this
7. now remove the little black switch caps (there are 4 of them for 4 windows). you can pry them out with a flat head screw driver. have patience! this is also a lil tricky
8. now that that the switch caps have been removed you can remove the black rubber piece.
9. now that everything thing is exposed you can remove the lil white switch using a small flat head screw driver.
10. once that is done you will see the inside of the switch. you can see that all the dirt has built up and cloged the connection from making contact. (this sorta works like the post of the battery when all the crust has built up and keeps your car from starting) well this is what kept your window from rolling up or down. get a small flat head screw driver and start scraping away the dirt from the metal.(make sure its cleaned out good)
11. inside are 2 little "v" shape pins, take them out and clean them out as well
12. after you clean out everything and scrape it up so it can make a connection, your all done. reverse the process to finish the job...everything should be working fine after this. (remember that i only did this for one of the switches. there are 4 of them. you can do this to all 4 if you would like or just do the one that is not working. this is my first diy and i hope it helps yall out a lil bit. sorry about the pics, i used the camera phone since i dont have the real digital camera. well good luck and have fun!!!
well thats about it...PEACE!!!
      Registered and logged-in users don't see this ad!
Register your free account today.
95 Honda Accord Ex. Stock
90 Honda Civic Hatch. Dohc zc
My EF project thread
DaNnYsEvEn is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 02-11-05, 03:05 PM   #2
JL95AccorD
JL95AccorD's Avatar
Send a message via MSN to JL95AccorD
Cool. I'll definately try this out tomorrow. I thought I was going to have to buy the complete peice new, or go and find one at a junk yard. Thanks.
JL95AccorD is offline   Reply With Quote
Old 02-12-05, 02:17 AM   #3
Provocateur
On permanent hiatus
Good writeup. Nice to know that there is someone who cares about the little things.
Provocateur is offline   Reply With Quote
Old 02-12-05, 10:29 PM   #4
DaNnYsEvEn
ThInK PiNk!
DaNnYsEvEn's Avatar
thanks! well just tryen to look out for those who want to save some money!! (like myself!) and those who want to take care of their "babies" and keep them clean!
Old 08-26-05, 01:22 AM   #5
drslowens
Thank you
Cleaned the power window switches as you described and with only one slightly broken piece of plastic, all the windows now work. thanks
drslowens is offline   Reply With Quote
Old 08-26-05, 08:34 AM   #6
lkailburn
college kid
lkailburn's Avatar
Send a message via AIM to lkailburn
very nice bro. the little writeups are where its at.. i have manual windows tho o well heheh
lkailburn is offline   Reply With Quote
Old 08-26-05, 01:21 PM   #7
fjm1
G35
fjm1's Avatar
great writeup!
Atheism is a non-prophet organization
fjm1 is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
