Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 01-31-05, 11:39 AM   #1
oc9crx
Help! tranny leaking
The tranny on my crx is leaking so I jack up the car and look under and it seemed to be leaking from where the axle meets the transmission so I was told to replace the axle seal, so I did but its still leaking. Any other possibilities.
      Registered and logged-in users don't see this ad!
Register your free account today.
oc9crx is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 01-31-05, 12:54 PM   #2
12yearhondatech
The axle seal should of fixed the leak unless there is a nick on the inner cv shaft where the axle seal rides or maybe you did not get the axle in all of the way it should almost be flush with the trans. Possibly you may have damaged the new seal when you installed the axle, after installing the new seal you need to grease the inner grove off the seal and also put grease on the inner cv shaft where it slides into the trans. make sure the inner cv does not touch the new axle seal when installing because it can tear very easy.
12yearhondatech is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
