Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 01-31-05, 08:57 AM   #1
Pitch11
HELP Hydrolic line
Turns out i have air getting into the clutch line.... How can i find the leak? Can you test the line somehow?
      Registered and logged-in users don't see this ad!
Register your free account today.
Pitch11 is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 01-31-05, 02:08 PM   #2
JimBlake
You just replaced the master cylinder, right? (I saw your other thread.) Did you bleed the clutch properly? Usually if you don't bench-bleed the MC, it takes a while to work all the bubbles out of it. Keep bleeding...
The line should be steel except for the short rubber section near the slave. Have someone pump the clutch pedal, then hold it down on the floor. Watch for leaks down there. Watch for the rubber section ballooning up with pressure (it shouldn't). Watch for leaking from the rubber accordion-boot around the slave piston rod.
JimBlake
'03 Accord, '07 Civic
'01 Saab 9³, '05 9²x
JimBlake is offline   Reply With Quote
Old 01-31-05, 06:52 PM   #3
Pitch11
Well a friend and i bled the line for 2 hours yesterday, also replaced the slave cylinder before that... the rubber line doesn't seem to be leaking... i'm to the point of going over the line a 10th time inch by inch. The result is the same... squishy clutch that works the first time right after we bleed... i mean could it be the throwout bearing?.... basically the clutch wont disengage.
Old 02-01-05, 11:18 AM   #4
JimBlake
Describe your bleeding technique. On mine, when I let fluid out of the slave, the clutch pedal doesn't spring back up. I have to pull it. If I let the pedal snap up, it can get some air in the MC rod seal. So I put a piece of string around the pedal to pull while my foot is on the pedal. That way I lift the pedal smoothly instead of letting it snap.
Watch the throw-out fork when your friend pumps the clutch pedal. It should move about 12 or 13mm back & forth.
How about fluid inventory? The reservoir is so small that you'd notice a leak just by the level going down.
I can't see it firsthand, but it seems like you've checked all the right things & now it's time to think about problems inside the bellhousing.
JimBlake
Old 02-01-05, 01:43 PM   #5
12yearhondatech
Here is the easyest way to bleed the clutch slave/ clutch master. First you need a small oil pump can [ what you use to oil engine parts when you are putting a motor together ] and a piece of vaccun hose about 2-3 feet long. Attatch the vaccum hose to the oil can and fill the can with brake fluid. First thing you need to do is try to remove what fluid you can from the clutch master resovore. Second make sure the clutch pedal is in the upright position, then losen the bleeder at the clutch slave about 1-2 turns then attach the vaccum hose to the bleeder screw and pump fluid in slowly you will see the resovore starting to fill up with fluid and bubbles when the fluid gets to the top of the resovor close the bleeder valve. Now the pedle should be normal you just need to bleed it 3-4 times the reuglar way now and you are done.
12yearhondatech is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
