| Do It Yourself This is where you will find step by step instructions so you can Do it Yourself! |
Thread Tools | Display Modes |
#1 | |||||||
How can you "kill yourself"?
| Sponsored Links | ||
#2 | |
2 tone Rex
Quote:
Some OEM springs are about 4 inches taller than they are on the shock... So when u take off the nut, it will pop off, and possibly hit u... And if its compressed, 4 inches, thats alot of pressure... Its not worth the risk... Just use a spring compressor! |
#3 | |
Quote:
99 civic its compressed MAYBE an inch |
#4 | |
2 tone Rex
Quote:
So, the chic u took home from the club last night MAYBE clean... Did u wear a rubber? (hypothetical ofcourse, to prove a point) |
#5 |
Banned
is it dangeroud or not.if its not i would like to do it on my car
#6 | |
Quote:
Yea you should probably use the spring compressor like "EXEMPT" said above, but I still think its not that dangerous without one if you are smart about it. |
#7 |
even smart people can be clumsy and hurt themselves
-- 5th gen Accord - 4dr VTi -- |
#8 |
On permanent hiatus
Don't be dumb. Rent the part from autozone for free and avoid killing/hurting/maiming/decapitating/etc. yourself over springs.
#9 |
Mr Clutch
I read in one of these import mags..... place the spring in between two of your tires( remove them from the car of course) while removing the bolt,.. and let them do all the catching of any force.
Sounds good to me.
Le Enfant Terrible |
#10 | |
Quote:
#11 |
FuK JDM
i've seen the spring pop off on my friends maxima....scary stuff
I <3 my Honda. 98 Integra RS 180whp 130 Trq |
#12 |
but i poop from there
what in the hell is this about...
#13 |
Yea. Nice topic.
I could think of plenty of ways, which i'd never do. There's been 3 people i went to school with that actually killed themselves. They seemed to be pretty normal people in school. Some peoples brains just are'nt right i guess. Life could never get that bad.
#14 | |
Quote:
..::Take a chance to recognize that this could be yours::.. |
#15 | |
On permanent hiatus
Quote:
#16 |
i bougught a set of spring compressors when i was first doing my suspension work...and it was a pain in the neck trying to get them on the springs...i used it on 1 f them and for the other three i just let it pop...it wasnt a big deal...didnt even shoot the nut..the cap stayed right where it was, so i wouldnt worry about it "killing" you..i also have done 3 suspension jobs on 3 different hondas since then, and didnt use the spring compressors..no problem worked just fine
http://www.cardomain.com/id/4gcivichatch |
#17 |
Banned
[u]you can go on top of a building on a crowded street.buy some kerosine,gray tape,and explosives(preferably c4 or c2} rub the karosine all over your body,then tape the c4 to your limbs like your legs,arms etc.then start yelling and get a lot of attention.dont let the police know you have explosives or they'll clear the area.then when you have enough people watching,and maybe a news crew or two,you can light your self on fire yell like crazy and jump off.then your limbs will explode and send your legs and arms flying into the people below.hopefully hurting someone else.go out with a bang![
#18 |
4500rpm hesitation
Just take the nut off with your teeth and let darwinism take over.
///'s |
#19 | |
On permanent hiatus
Quote:
#20 |
chris is the devil
I eventually want to swap out my Koni yellows and H&R race springs.. for Teins. Will i need a spring compressor or are lowering springs easier to remove from the car?
05 Acura RSX Type-S Beater- ![]() |
#21 |
I don't know why people say you need a spring compressor. All you have to do, is have the car on jack stands, and then use a floor jack to jack up that wheel to compress the spring. Then undo it, and slowly jack it back down.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
