Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 10-30-04, 01:50 AM   #1
jweltch
Closet Ricer
Timing belt replacement..what the hell?
Car: 1995 Civic
Engine: D16Z6
I'm replacing the timing belt (among many other parts).
Both manuals I've looked at tell me to remove the power steering pump and both say not to disconnect the lines. Fair enough..
Only problem is that there are metal lines going into the rubber lines. The rubber lines aren't long enough to "move the pump out of the way". I'm also trying to move the reservoir, same problem. There are 2 pairs of metal lines: 1 pair goes toward the front (power steering cooler?), while the other pair go toward the rear (these wrap around the motor mount). I've removed 2 mounting brackets in an effort to make the metal lines easier to move but no dice.
How do you guys do it? Should I just disconnect the lines and bleed the p/s when I'm done?
      Registered and logged-in users don't see this ad!
Register your free account today.
jweltch is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-04-04, 01:01 PM   #2
bnuk
bnuk's Avatar
Send a message via AIM to bnuk
on my tegra it was fairly tight if you just pop the resivior out of its braket you can kinda slide them both over to right. still somewhat in the way though.
98 integra GSR
93 civic DX
82 nighthawk 450
bnuk is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
