| Do It Yourself This is where you will find step by step instructions so you can Do it Yourself! |
Thread Tools | Display Modes |
#1 | |||||||
93 civic with 90 000 miles, what sort of things need to be serviced on it?
| Sponsored Links | ||
#2 |
Timing belt & valve adjustment. Maybe the water pump since it's right there at the timing belt?
Fresh brake fluid & fresh antifreeze every 2 years. When's the last time for that? How about brakes? You can't predict that with mileage, since everybody drives differently. But it can't hurt to inspect them real good.
JimBlake '03 Accord, '07 Civic '01 Saab 9³, '05 9²x |
#3 |
While you're doing the timing belt/water pump you may as well replace your accessory belts (power steering, a/c, alternator). You'll be draining you coolant so check your hoses and replace them as needed. Sounds like you should be in good shape otherwise.
#4 |
Still here... sorta...
no need for the double post. If you have input toward this thread make your post in the Civic section.
2008 Lexus IS 350 - Starfire White 1999 Ford Explorer 4x4 Sport View My Feedbacks & ADD TO THEM!!! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
