Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 10-09-04, 02:06 PM   #1
luky1380
chek engine problem
i have 92 vigor and my check engine light came on, i loose all power when light comes on, engine won,t go more yhen 3000rpm's.i torn car off start back up rans good untill engine light comes back on again. i checked codes - it showed cranck/tdc/cyl sensor. damn $220 . ireplaced and it gave me same problem i checked resistance of ich wire - no problem. reset the code same think light comes back on replaced ECU runs perfect for 2 days then same problem and its happened only when car is hot
please any body help
thanks
      Registered and logged-in users don't see this ad!
Register your free account today.
luky1380 is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 02-10-05, 09:02 PM   #2
Jesus Man
How about the Oxygen sensor ? Has this been going on awhile ? Did it run ok and slowly get worse , as you started to lose power and you would have to shift down to get RPMS up and just to keep it going ? Then it went to no power finally and would be cutting out till you have to stop because it seems as if it was starving for fuel ? If so your Oxygen Sensor is toast and has been telling your motor it needed more fuel till finally it just dies. when you run the car this time and it dies on you get out look under your car best at (nitetime) .If you see a glowing red under car thye Oxy senssor has feed so much more fuel than fuel air to your Cat Converter & that is the glow. The Cat is coming apart from the fuel and is blowing into exhaust pipe jamming it with the fibers from the Cat Converter. Thus robbing the car of power and the longer you go it will blow all into your exhaust pipe to muffler till it wont run at all . If it hasnt damaged it all the way you wont have to replace every thing from cat back out to tail pipe. Just a guess ? Tail pipe where exahust comes out will be extra HOT you wont be able to hold your hand at tail pipe before your hand gets burnt...
Jesus Man is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
