Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 10-07-04, 01:46 PM   #1
72soa
brakes on an odessey
I need new brake pads for my 2002 honda odessey and have some questions.
1) Can I use pads from the local autoparts store or do I really need to buy the honda pads at the dealer? The dealer wants to rape me IMO.
2) Car has antilock brakes. Can I just compress the caliper piston with a c clamp without trashing my anti lock brake system. I have been told that I will need to clamp the brake hose and then open the bleeder screw on the caliper to comperss the piston. I dont want to bleed the brakes.
3) What, if any tricks are there for doing the rear?
4) Anything else?
thanks
      Registered and logged-in users don't see this ad!
Register your free account today.
72soa is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-07-04, 05:12 PM   #2
JimBlake
OEM pads are pretty good, there's lots of others. I'm sure autoparts stores sell good ones alongside junk ones... Search, there's probably lots of threads arguing about what kind is better than the others.
Just compress the piston into the caliper. The reason for opening the bleed screw is so you don't push too much fluid back into the reservoir & overflow. Open the bleeder a little while you're pushing the piston, close it before you quit pushing. That way you don't let air in.
I know you said you don't want to bleed the brakes, but this is a good excuse to bleed fresh fluid thru the whole system. It picks up moisture from the air & that makes it corrosive.
I don't like to ever pinch the hose, & never let the weight of the caliper hang on the hose. I've had a hose burst while stopped for a train & I didn't like the feeling...
The trick for the rear is twist the pistons, don't just push them in. That's because of the handbrake auto-adjusting mechanism.
Make sure the caliper slide pins are greased & they slide smoothly. Make sure the new pads fit nice into the caliper brackets. Sometimes I have to file the paint off their ends so they don't wedge too tightly. Little grease or anti-seize is good where they move.
JimBlake
'03 Accord, '07 Civic
'01 Saab 9³, '05 9²x
JimBlake is offline   Reply With Quote
Old 10-08-04, 08:29 PM   #3
luky1380
1)yes
2)yes you can compress without problem im doing this for 10 yrs
3)yes you need spesial tool for compress calliper or you can get big prybar twist calliper clockwise und push it at same time
luky1380 is offline   Reply With Quote
Old 10-09-04, 03:13 AM   #4
Provocateur
On permanent hiatus
Autopart store pads can be good or bad. The general rule of thumb is: you get what you pay for. I would go with OEM brakes. Yeah, they are expensive but...they are relatively silent compared to most autopart store pads and they are relatively high quality.
I wouldn't recommend even touching the bleeder screw. Just compress the front caliper piston with a C-clamp or piston compressor tool...shouldn't be a problem.
The rear requires you to screw the piston back in. Use a flat head screwdriver to do this or go and buy a rear piston compressor tool. Also, be careful not to twist or tear the piston boot when backing the piston back in to the caliper.
One last thing...lather the back of the pads and contact points on the caliper with the supplied anti-squeal grease.
Provocateur is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
