Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 10-02-04, 06:45 PM   #1
joey t
Send a message via AIM to joey t
Header Gasket
I Installed A Header On My 2003 Civic A Few Months Ago. I Just Noticed Today That The Gasket I Made Is Starting Too Fall Apart. Its A Cork Type Material The Guy At The Part Store Told Me To Use It. What Type Of Gasket Materiale Should I Get And Where Can I Buy It At. Thanks For Your Help.
      Registered and logged-in users don't see this ad!
Register your free account today.
joey t is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-02-04, 07:03 PM   #2
lkailburn
college kid
lkailburn's Avatar
Send a message via AIM to lkailburn
??? why did you double post tihs?
lkailburn is offline   Reply With Quote
Old 10-02-04, 07:05 PM   #3
joey t
was just trying to get a quick anwser sorry. theres a small piece of my header gasket missing. is it okay to drive the car like that. so new to this honda thing
Old 10-02-04, 09:50 PM   #4
lkailburn
college kid
lkailburn's Avatar
well you may or may not have a leak with a chunk of your gasket missing. go get an oem gasket from a honda dealer. its most likely a metal gasket.
Old 10-03-04, 03:29 AM   #5
88IntegraRS
The guy at the parts store is an idiot -- cork is never used for hi-temp gaskets like a header! Gaskets used for exhaust temps like headers and EGR usually have a coating like perforated aluminum foil. Check out the original gasket, or just get a factory gasket and you should be in business.
88IntegraRS is offline   Reply With Quote
Old 10-03-04, 12:10 PM   #6
joey t
okay im going monday and buying 1 from the honda dealer. my only other question is when i put the header on the car the header is slightly bigger then the factory part and if i use a factory header gasket will it still work?will it make a nice seal? thanks
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
