Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 06-12-04, 04:43 PM   #1
sabotage
brade pad installation gone bad!
so i decided to change my own pads for the first time and used the article on here as a guide. problem was i coudlnt get the piston on the front brake back in, so what i did was pump the brakes a bit hoping to maybe loosen it. big mistake. it practically came all the way out, and when i tried to push it back brake fluid leaked out and then it stopped. anyone have any ideas as to what i should do?
      Registered and logged-in users don't see this ad!
Register your free account today.
sabotage is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-12-04, 06:10 PM   #2
Junolude
use a big c clamp to compress it? Maybe try draining your brake lines so theres no pressure behind it. then make sure you refill your brake lines and bleed them.
Junolude is offline   Reply With Quote
Old 06-12-04, 09:33 PM   #3
sabotage
yea a c clamp worked fine. and it works alot better if you clamp it in the middle, not the edge. if only i knew that sooner.
Old 06-13-04, 12:20 AM   #4
slammed91-hatch
slammed91-hatch's Avatar
Send a message via AIM to slammed91-hatch
when i do it i leave the old pad in there so there is more of a flat surface for the clamp to go on. but yes the C clamp is the way to go with this.
mods: ls swap, hasport mounts, intake, header, full exhaust, rear sedan door handles, dei alarm with remote door locks, relocated optima battery, no ps or ac, skunk2 coilovers, 17 inch rims, wings west sides, opium front, extreme rear, custom painted tails, jdm corners, 95 gsr center console, 92 teg steering wheel, 2 12" mtx 8000 subs and mtx 6500D amp, body work and paint coming soon.
slammed91-hatch is offline   Reply With Quote
Old 06-13-04, 03:25 PM   #5
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
There's even a tool available specifically for compressing the front caliper piston. Glad you got it working.
2008 Lexus IS 350 - Starfire White
1999 Ford Explorer 4x4 Sport
View My Feedbacks & ADD TO THEM!!!
westcoaststyle is offline   Reply With Quote
Old 06-14-04, 09:50 AM   #6
sabotage
is there any other way to put the rear caliper piston back in besides using a big screwdriver?
Old 06-15-04, 12:27 AM   #7
honura
Seni
honura's Avatar
Send a message via AIM to honura Send a message via Yahoo to honura
Quote:
A hammer!
honura is offline   Reply With Quote
Old 07-12-04, 02:06 PM   #8
Daniel
Douchebag
Daniel's Avatar
Send a message via AIM to Daniel Send a message via Yahoo to Daniel
Quote:
Originally Posted by honura
A hammer!
You wouldn't want to hammer in the rear calipers. Follow Josh's method, that works!
Out of curiosity, what was the article that you followed? That should have been addressed. Also, applying your brake pedal with the brake assembly apart isn't a great idea. As you saw, your piston will slide right out, as there's no object or force retaining it in.
I'm a douchebag
Daniel is offline   Reply With Quote
Old 07-14-04, 09:05 PM   #9
ExiledinIN
ExiledinIN's Avatar
It's better to use the tool on the rear to make sure that you are not going to tear the boot. Tear the boot or get the boot crimped up (which leads to seized calipers) will mean to get a new caliper. Better to spend the $9 at Napa.
http://www.napaonline.com/cgi-bin/nc...&usrcommgrpid=
ExiledinIN is offline   Reply With Quote
Old 08-30-04, 02:44 PM   #10
honura
Seni
honura's Avatar
I was joking around!
Old 06-15-04, 01:23 AM   #11
Sham
Send a message via AIM to Sham
I went to Schucks, auto parts store, and bought a special $12 tool to screw the rear piston back in. One side felt like it wasn't going to move a bit, the other side felt like it was sliding through butter. Get the tool.
Sham is offline   Reply With Quote
Old 07-12-04, 02:40 AM   #12
Provocateur
On permanent hiatus
The tool is pointless. Save yourself $12 and use a flat head screwdriver. It works best when the head is exact size of the opening. Also, if the boot is being twisted, WD40 it and it will stop.
Provocateur is offline   Reply With Quote
Old 07-12-04, 08:07 AM   #13
ls_101
integra fs
ls_101's Avatar
do not use a screw driver to push the piston into place it can go in crooked then your screwed, use a c clamp, do not use wd 40 on the boot it is oil base and will cause the rubber boot to deteriorate, causing future problems, remember to put anti sieze on the slide pins before reinstalling them, use a water/synthetic base lubricant on the rubber boot to protect them, do it right the first time so u dont have to do it again
i know this because i went to school for it
ls_101 is offline   Reply With Quote
Old 07-12-04, 01:42 PM   #14
westcoaststyle
You do not want to use a C-clamp on the rear caliper because you have to screw it in to get it to retract. A C-clamp will only press it in and that won't work. I also use a screwdriver. Instead of using it as you normally would, lay the screwdriver on its side and use it long-ways in the groove. It gives you more surface area and the right size screwdriver will lay perfectly in the groove giving you great leverage.
hih
Old 08-30-04, 02:24 PM   #15
intjinfj
Just FYI used C clamp to push the piston on the rear brakes back in and now I have to replace both rear calipers. Buy tool saves you $120+ dollars plus the time of re-doing it. DOH!!!!!!!
intjinfj is offline   Reply With Quote
Old 08-31-04, 02:19 PM   #16
SRD_DC2
Dont forget to put your e-brake down before you replace the rear pads
SRD_DC2 is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Bad power steering pump? jcd2num1 Accord 3 05-20-03 04:21 PM
I may have a bad IACV... AwwsChwA Engine Swaps, Tech & Tuning 4 04-30-03 05:43 PM
1992 Gsr For Sale (bad block) 98RedGS Parts Classifieds 4 01-23-03 10:44 AM
Amp's fuse went bad tripods4u Audio & Security 3 01-02-03 08:03 PM
bad bad situation mstrpimp02 Engine Swaps, Tech & Tuning 1 10-08-02 12:15 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
