Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 06-07-04, 05:26 PM   #1
Special K
Warm AC......
Hey, it's the first actually warm day and to my luck my A/C has apparently gone somewhat south... Anyways, it's fairly warm, but it's still slightly colder than regular 'cold' airflow. Anyways, I figure it's either a leak somewhere, the coolant chemical (can't remember the name), or one of the other parts is shot. All of the other components to the ventilation system work fine, it blows high and low and heat is fine, just the AC is crap.
Has anyone had this problem? Does anyone know a relatively easy fix or ways of inspecting?
Thanks!
      Registered and logged-in users don't see this ad!
Register your free account today.
"Friends will help you move. Good Friends will help you move bodies."
Nihilists! Fuck me. I mean, say what you like about the tenets of National Socialism, Dude, at least it's an ethos.
Special K is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-07-04, 06:29 PM   #2
hondatech
Honda tech/eprom hackr
hondatech's Avatar
Send a message via Yahoo to hondatech
Sadly it sounds like a leak. A/C is usually expensive and not easy to fix by yourself unless you know what to do and have the proper cert. to repair automotive a/c systems. I paid over 400 dollars last summer to fix my girlfriends 93 accord and that was just parts, I did all the labor since I'm a technician. Let's see those parts were like 300 for an evaporator/expansion valve, and about 100 for R12. That was for a leaking evaporator. Just one part and it adds up. You need someone to tell you what's wrong.
hondatech is offline   Reply With Quote
Old 06-08-04, 12:41 PM   #3
96GreenCivic
96GreenCivic's Avatar
Send a message via AIM to 96GreenCivic Send a message via Yahoo to 96GreenCivic
Quote:
Wow, I'm surprised you were even able to get any R-12 refrigerant. Why did you just do an R-134a conversion since you were in there? Wouldn't that be cheaper in the long run?
96GreenCivic is offline   Reply With Quote
Old 06-07-04, 07:01 PM   #4
CRAIGHIMSELF
Rip riding
CRAIGHIMSELF's Avatar
Send a message via AIM to CRAIGHIMSELF
That sounds similar to mine. Except one day it was SUPER COLD AC and the very next day, like overnight, the AC was blowing warm. Unless I had a major leak I wonder why mine has done that. Maybe I blew something when installing my stereo that day...
CRAIGHIMSELF is offline   Reply With Quote
Old 06-07-04, 07:09 PM   #5
Special K
Strangely enough, that's when mine crapped out too... I gutted my interior to paint and do the stereo, and after that the AC was warm. It was really wierd... I never thought it would be attributed to the stereo... maybe it's just a fluke....
Old 06-08-04, 12:30 PM   #6
JimBlake
It's always possible you pulled a wire apart somewhere under the dash...
Lots of times when the AC 'suddenly' quits working, it's been leaking for a while. One day it 'suddenly' doesn't have enough pressure for the low-pressure switch. That switch is in there so you don't destroy your compressor by running it anyway.
JimBlake
'03 Accord, '07 Civic
'01 Saab 9³, '05 9²x
JimBlake is offline   Reply With Quote
Old 06-08-04, 04:40 PM   #7
atlfalconz112
Send a message via AIM to atlfalconz112
just take the a/c out of there and gain some hp plus they weigh almost 20 lbs
slammed '92 accord ex sedan
17" rss daiwa's wrapped in 205/40/17 kumho ecsta tires
lowered 3.5 inches on spw coilovers
si style tail lights
intake, exhaust
future mods: my next goal is to paint my trim out then drop an h22 into it......if anybody has one for sale let me know
atlfalconz112 is offline   Reply With Quote
Old 06-08-04, 04:44 PM   #8
hondatech
hondatech's Avatar
^^^^anyone else reading this? He has a good point which I didn't bring up. And he is also right, I should have converted to R134a and in the long run it would have been cheaper. With mine I was concerned about the age of the car and it's a/c componants. I was concerned the compressor wouldn't be able to take the extra stress of conversion. (R134a systems have slightly higher pressures). Nobody will convert your system to R134a and tell you that it will be a guarenteed success and that your compressor won't blow in 2 months. I think chances are it would have been fine but this is my car and i'm wierd that way. Accords seem to convert easily between R12 and R134a without problems, however I would recommend not to do it to a civic with a half condensor/half rad. I have never seen good results from the ones i did it to and i ended up converting them back. The high side pressure always spikes way to high and cooling in the cabin is weak. Around 45-50 f degees.
To comment on the R12, Ebay is a good source of old R12, I found it at places like PEP boys, kragens, napa, etc... Here's the catch, you have to have a lic. to buy it.
It's called a section 609 and it's easy to get. Do a seach if you're interested. Every year the price goes up. Get it why you can I guess.
Old 06-09-04, 04:29 PM   #9
Special K
OK, potentially noob question...... what's the difference between R12 and R134a? (anything to do with the difference in 96-98, 99-00 vent systems?) what would the benefits be to doing a convert, and can one be done on a 97 civic (assuming it involves more than just changing the coolant chemical?)
Reminiscing about my AC on the extremely hot drive home today I remembered that before my AC went to crap there were a few times I noticed that when I had it on it looked like dust or even faint smoke was coming out of the vents, it didn't have any scent or anything. AC worked fine while it was doing this, and it did for a summer, by the time the next summer rolled around the AC had crapped out. I thought the stuff was likely dust/dirt from the vents, but who knows...
Anyone heard of this? I just can't stand the thought of paying someone 1K+ to fix this.
Old 06-09-04, 05:30 PM   #10
JimBlake
R12 is a better refrigerant, but it hurts the ozone layer & it's now illegal to manufacture it. Still can be bought & used (with a license), but nobody's supposed to be making any more of it.
A '97 almost certainly came with R134a, so there's no conversion needed. Everybody switched over in the early '90s.
The mist coming out of your vents was probably water vapor. It was probably on a very humid day, right?
JimBlake
Old 06-09-04, 07:26 PM   #11
Mike Oxbigger
I checked my pressure line and the pressure was fine. I checked it with a store bought r134 recharger kit. What else could be causing my a/c to be on the warm side?
Mike Oxbigger is offline   Reply With Quote
Old 06-09-04, 08:16 PM   #12
Special K
From what I remember the days were more or less just warm days. I don't think it was vapour because at the time it was still cold air and the first time it happened I held my hand up against it for a few minutes to see if anything noticible would stick (condensation, dirt/dust or otherwise) and nothing was visible. I didn't feel anything either (aside from a coolish hand....)
hehehe... Oxbigger........
Old 06-10-04, 01:51 AM   #13
hondatech
hondatech's Avatar
don't worry about the mist right now, those recharge guages suck. Buy or borrow a real guage set. I think harbor frieght has some for R-134a for 49.99 which is super cheap considering snap-on charges close to 300. here's a link:http://www.harborfreight.com/cpi/cta...temnumber=2435
If you were to buy that you would be in business, then you know exactly what's going on. From the pressures and what hey do you can pretty accurately diagnose what's wrong.
Curious, does the compressor come on at all? When you hit the a/c button with the fan speed on at least the first line, does it make a click sound? If you look at the portion of the compressor where the belt rides the outside piece will move with the belt when it's actually running. You should have someone turning the button on then off while you watch.
Old 06-10-04, 02:47 AM   #14
Mike Oxbigger
hondatech, where is the heater valve on 5th gen accords?
Old 06-10-04, 03:19 AM   #15
hondatech
hondatech's Avatar
It's behind the engine lower pass. side of the fire wall. If you know where the tstat is, follow the heater hose from the outlet back to the firewall and you'll see it. It's a black box looking thing between the hoses, it will lhave a cable attached to it. Have someone move the cold/hot knob in the car and you'll see the cable move back and forth, then you'll know where it is.
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Taking forever to warm up saxtonpaxton '92+ Civic/EL & Del Sol 2 02-02-04 02:43 PM
car wont warm up hybridhondahatch '92+ Civic/EL & Del Sol 5 11-09-03 06:08 PM
warm heat-cold heat airwurthy-gsr CRX & Pre '92 Civic 6 01-17-03 01:49 AM
89 legend wont start when warm mccree Legend & RL 1 12-19-02 12:46 AM
Fresh air vent is all warm an !@$! thx247 Integra & '97-'01 Integra Type-R 10 11-19-02 08:25 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
