Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 06-01-04, 02:41 PM   #1
1998civicsi
Emblems!
whats the eastiest way to remove the rear hondo logo and civic emblems off my car? 98 civic si!
is there just rubber/sticky shit keepin it on the car or does it stick into the body(metal) which means bondo?
      Registered and logged-in users don't see this ad!
Register your free account today.
1998civicsi is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-02-04, 12:01 AM   #2
Redlinerz
Redlinerz's Avatar
the easiest way to shave you emblems...
.......Use bondo because fiberglass resin is too runny to seal the holes. First you wet sand the holes with 400 grit sandpaper so that the bondo has something porous to adhere to. I put about three coats of bondo on. The first application will be enough so that the next two have something to stick to. After that: Wet sand the area. Mask the three areas and primer. Remove the masking and wet sand again so it's extremely smooth with no ridges, dips, or grooves. Mask your hatch glass and surrounding area - you can't cover too much as the mist is quite fine. Then paint your hatch. If you use paint in a spray can - shoot several coats of clear coat afterwards. If you use a paint gun, as I did, the hardener will effectively seal the paint and make it nice and shiny.....
Hope it helps Have fun... good luck
Redlinerz is offline   Reply With Quote
Old 06-02-04, 12:04 AM   #3
Redlinerz
Redlinerz's Avatar
and for how to remove the emblems
...A good effective way is to heat up the sides of the emblems with a blow drier, not to burn it though, then slide a credit card or something like that under the emblems to cut the glue from underneath. Last use rubbing alcohol to remove the excess glue left on you car. Hope that helps...
Notes: Just use dental floss (make a double or triple strand) and put it between the emblem and the car. Works great, and no scratching. About the rubbing alcohol, my friend tried that on his GS-R and when he removed the white rag, it was red on one side!!!! Just a word of caution... I cant think off another way to get that glue off though... hope it helps.. Good Luck
Old 06-02-04, 08:31 AM   #4
lkailburn
college kid
lkailburn's Avatar
Send a message via AIM to lkailburn
to remove the "civic" and like "dx" or "ex" badges, just grab some dental floss.. and use it like a saw to cut through the sticky stuff behind the emblem. may take you like 2 peices, but it will work. then use goo gone to get all the sticky off the car. don't use rubbing alcohol.. WAY too harsh for your paint imo
tips with the goo gone:
-try as much as you can to let the goo gone soak into the sticky stuff.. the more you can get to soak on, the easier to remove.
-goo gone recommends you wash the area after using their product
EDIT: i just saw that redline's post included the dental floss trick.
lkailburn is offline   Reply With Quote
Old 06-03-04, 12:39 PM   #5
Redlinerz
Redlinerz's Avatar
i never knew they made "goo gone" ... i guess that would be a whole lot better then using rubbing rubbing alcohol and having a big blank spot wit no paint where your emblem used to be..
Old 06-03-04, 01:49 PM   #6
lkailburn
college kid
lkailburn's Avatar
^^^^ hahaha yep
Old 06-03-04, 02:47 PM   #7
slammed91-hatch
slammed91-hatch's Avatar
Send a message via AIM to slammed91-hatch
this stuff called goof off works better than goo gone.
mods: ls swap, hasport mounts, intake, header, full exhaust, rear sedan door handles, dei alarm with remote door locks, relocated optima battery, no ps or ac, skunk2 coilovers, 17 inch rims, wings west sides, opium front, extreme rear, custom painted tails, jdm corners, 95 gsr center console, 92 teg steering wheel, 2 12" mtx 8000 subs and mtx 6500D amp, body work and paint coming soon.
slammed91-hatch is offline   Reply With Quote
Old 06-03-04, 06:25 PM   #8
1998civicsi
but is there holes its in?
but is the emblems just glued on there with glue or rubber from the factory or does part of the emblem stick into through the body to keep it on the car?
Old 06-06-04, 12:06 AM   #9
wedley2
bboy Wesley West
wedley2's Avatar
Send a message via AIM to wedley2 Send a message via MSN to wedley2
Quote:
usually its just the H that has two holes and sticky stuff around the sides...
Vid of the Week:Nasty Ray kills the beat.
Dickies.Reebok.AdidasApparel.Mcdavid.Tribal
wedley2 is offline   Reply With Quote
Old 06-13-04, 05:39 PM   #10
JET
what kind of goo gone do you get? just the regular kind? or do i need the automotive? you can also get a spray kind... ?
JET is offline   Reply With Quote
Old 06-13-04, 05:55 PM   #11
wedley2
bboy Wesley West
wedley2's Avatar
Quote:
goo gone only comes in one form whr i buy it, lol
Old 06-13-04, 08:34 PM   #12
JET
so i saw it off, then spray goo gone on it, let it set for ? minutes, and then just wipe it off with a towel? thats it? am i missing anything?
Old 06-13-04, 10:33 PM   #13
lkailburn
college kid
lkailburn's Avatar
i just use the regular goo gone not the gel form. as for the civic and model emblems, just use floss to "saw" them off.. goo gone it and be done. i haven't removed the H emblem personally but i know its held into 2 holes by plastic pegs. idk if you can just pull it out or you actually have to cut off the plastic pegs.
Old 06-14-04, 08:28 PM   #14
00CivicSleeper
Just Beginning...
00CivicSleeper's Avatar
Has anyone had a problem with an outline of their emblems? I just took mine off, and I can still notice a light outline where the edges of the emblem was. I dont think its from faded color, do I just need to leave GooGone on longer?
00CivicSleeper is offline   Reply With Quote
Old 06-14-04, 10:15 PM   #15
lkailburn
college kid
lkailburn's Avatar
^^yup
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS: Blue Honda "H" Emblems 92-95 Civic 4dr rexerin Parts Classifieds 2 09-02-03 01:39 PM
original 'H' emblems? asdill '92+ Civic/EL & Del Sol 13 07-11-03 03:05 PM
Blacking out emblems rabican Prelude 6 05-20-03 08:00 PM
Question about Swapping A for H emblems travis200 Integra & '97-'01 Integra Type-R 23 02-11-03 09:02 PM
DC Sports emblems and license plate frame howiedoit Parts Classifieds 1 08-22-02 01:21 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
