| Do It Yourself This is where you will find step by step instructions so you can Do it Yourself! |
Thread Tools | Display Modes |
#1 | |||||||
Cel Codes
| Sponsored Links | ||
#2 |
Card carrying badass
On my civic (1992 DX sedan) the jumper is tucked up underneath the passenger's side dash/kick panel seam area. With the car off and the key out of the ignition, I took a paper clip and used the clip as a jumper between the holes. Then you put the key in the ignition and turn it to accessory level. The light will flash long for tens and short for ones and give a long pause between codes. If you download the Helms you can interpret the code you are given. Or I guess you could always ask it here.
#3 |
Still here... sorta...
2008 Lexus IS 350 - Starfire White 1999 Ford Explorer 4x4 Sport View My Feedbacks & ADD TO THEM!!! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| RSX CEL codes | cbsevenzero | RSX & '02-'05 Civic Si | 2 | 08-09-04 12:34 AM |
| Questions on CEL Codes | Scrub91DX | Engine Swaps, Tech & Tuning | 3 | 06-12-03 05:00 AM |
| What happens when I jump the blue plug to check my CEL codes and... | OneToughCivic | '92+ Civic/EL & Del Sol | 19 | 09-26-02 12:54 AM |
| need help w/ cel codes | long | Engine Swaps, Tech & Tuning | 1 | 09-11-02 06:01 PM |
| cel codes | mrmatt421 | '92+ Civic/EL & Del Sol | 9 | 07-29-02 12:19 AM |
