Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Prev Previous Post   Next Post Next
Old 05-24-04, 08:26 PM   #1
talented_minds
talented_minds's Avatar
Send a message via AIM to talented_minds
Fuel Problem?? HELP ANYONE???
wassup everyone well here it is,
I got this car a 1990 honda Civic DX (4 door) for $400 with 90,000 miles on it. When i start the car from a cold start It starts rite up on the 1st crank, But i noticed it didn't start 1 day after I shut it off and this problem persisted after i shut it off it will not start untill basicaly it's ready. After i start the car and let it idle and i step on the gas the motor accelarates but i notice a flat spot when i continue to step on the gas (like a hesitation or buck). So i took the car around the block and that's exactly what it does, sometimes at no particluar idle or at same place every time but only when gas is being stepped on. It's a (hestation or a buck). The car has been sitting for over a yr or so, Is it possible to have condinsation in the fuel tank that is making it to do this? The car hasn't been driven for more then a half a tank of gas. I think it's either the fuel pump or the fuel injectors (I think this model DPFI has only 2 fuel injectors.) Can it be the fuel regulator that is under the hood mounted on the firewall? Can it have a fouled plug or fuel injector, but like i said it doesn't do it every rotation of the crankshaft (such as in the firing order.) It's getting a spark when it doesn't start. I'm a backyard mechaninic, all i got is my tools and my Chilton Repair Manual. It's easy to fix something if you know what the problem is but in this case I dont know where to start? Any advice anyone?
      Registered and logged-in users don't see this ad!
Register your free account today.
talented_minds is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
need help! fuel problem 95GSX_R6 CRX & Pre '92 Civic 5 10-17-03 08:49 PM
Honda Introduces Breakthrough Fuel Cell Stack that Operates at Below Freezing Temp. Daniel News & Rumors Archives 0 10-10-03 12:45 PM
GSR w/ fuel problem undrgrndhaqer Engine Swaps, Tech & Tuning 10 05-14-03 11:14 PM
DOT tightening SUV fuel rules jaje News & Rumors Archives 12 12-27-02 12:41 AM
Fuel & Sensor Problem.. Help undrgrndhaqer Engine Swaps, Tech & Tuning 8 12-21-02 07:01 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
