Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 05-15-04, 12:34 AM   #1
etrauty
Help !!
Anyone out there good with wiring, got a quick question, I Did the Vtec Light diy, worked out pretty good. But I want to add another LED, I tried a tie clip to the other LED then routed that to the Vtec selonoid. But just that one LED will light up, So question is, Is there another way to wire that second LED, or what am I doing wrong???
      Registered and logged-in users don't see this ad!
Register your free account today.
etrauty is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 05-15-04, 01:13 AM   #2
lkailburn
college kid
lkailburn's Avatar
Send a message via AIM to lkailburn
from what i know about wiring:
if you try running 2 led's off that power they will only run at half of what they need. assuming the diy was made to handle only one led. in which case you might only see one light up because there isn't enough juice getting to the second one to even light it up.
idk maybe i'm wrong? but i know if you wire up 4 led's pos to neg in series and stick em in a 12v connecter they should all light up at a correct voltage(about 3v each)
lkailburn is offline   Reply With Quote
Old 05-15-04, 01:51 AM   #3
etrauty
Makes sense, I still want to find a way to make my light brighter though.
Old 05-15-04, 01:59 AM   #4
Bl@ck
Sinner
Bl@ck's Avatar
Send a message via AIM to Bl@ck
try reversing the polarity going to the one that isn't lighting. diodes only work with current flowing in one direction
Quote:
Originally Posted by Princess Mandiala
oh someone shoot me in the mouth now
Bl@ck is offline   Reply With Quote
Old 05-17-04, 10:40 PM   #5
onecommonvoice
Send a message via AIM to onecommonvoice Send a message via MSN to onecommonvoice Send a message via Yahoo to onecommonvoice
Vehicle Speed above 13MPH (3MPH for A/T) the Electronic Control Module (ECM) activates the VTEC system by sending a 12volt signal to a solenoid. We just want to hook up a light in parallel with this solenoid and steal a little power so the light is on when VTEC is activated. Each car is a little different in which wire is used for the signal.
onecommonvoice is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
