Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 01-25-04, 04:11 PM   #1
VTECin5th
DIY VTEC light.
i made one of these about 8 months ago, and it still works fine.
custom vtec light.
1 12v lightbulb, your choice of color, tho, white or blue is best.(2.99 at autozone)
20 feet of 18 to 20 gauge wire.
Clear folders from walmart, comes in a 5-6 pack for like $3.00, comes with white, blue, purple, red, yellow and green, they are SEE THRU FOLDERS, thats important u buy the right ones.
A printer, and some basic car knowledge.
Start by taking the entire gauge bezel out.
Drop the lightbulb into of the slots NOT being used by another light.
(Brake, check engine etc.)
Attach a wire to one side of the light and run that wire to the NEGATIVE, you can choose to run that wire to any ground, but i ran mine back to my battery, just because.
Attach another wire to the other end of the light bulb.
time for a terrible drawing.
--- drop light in from FRONT of cluster
-----------|(drop)|----------------
--- back ---- BULB ------guage----
------------|n--|p
------------|e--|o
------------|g--|s
ok for the non electricity inclined, the "neg" is the ground, attach that to any metal thats grounded to the body.or the (-) on the battery.
Pos wire, plug that into your VTEC solenoid.
go for a ride, BEFORE you put ur guage back in, and make sure u wired it right, so it will work..
if it works, go inside, and print "vtec" or VTEC in the smallest font u have,
on your choice of the colored folders, cut it out, DONT TOUCH the ink, it will smear,put a piece of clear tape over it, so it stays in place.
then tape it into your guage cluster, carefully and cleanly.
ill include a pic of the finished product, ill get a pic of the light on too..(later)
hope this helped someone.
look at the bottom right indicator light.
lateX
      Registered and logged-in users don't see this ad!
Register your free account today.
95 Ex coupe
VTECin5th is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
vtec light install breckercivic '92+ Civic/EL & Del Sol 15 05-19-05 07:25 PM
Nearly every Honda USDM, JDM and EDM engine code accorduk Engine Swaps, Tech & Tuning 41 05-03-05 02:44 AM
still having trouble - vtec light breckercivic '92+ Civic/EL & Del Sol 13 12-05-02 08:45 AM
installing vtec light breckercivic '92+ Civic/EL & Del Sol 33 10-28-02 04:39 PM
turn signal bulbs ElectronBlueGSR '92+ Civic/EL & Del Sol 12 06-21-02 11:58 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
