Ls Engine Build
Old Jan 4, 2004 | 10:40 AM
forzracer's Avatar
forzracer
Default Ls Engine Build
I have a 93 Integra Ls with hight miles and Im trying to boost the power. I have all the parts for a mild turbo 5-6 PSI boost and have new valve springs, and was planing on haveing the head ported and polished, and have the valves reseated. I was wondering what I had to do to the bottom end to get it ready for the restored compression, and added pressure. the only problem is I'm on a tight budget and can only afford to do the minimun, to make sure my car dosent turn into a smoke bomb.
Old Jan 5, 2004 | 01:48 PM
PHiZ's Avatar
PHiZ
BOOST GOD
you should be able to make almost 300hp on a stock LS motor, if you can get the headwork cheap, go for it, otherwise it does not really increase the reliability of the motor.
For reliability replace the wear items, rings, water and oil pumps, gaskets and seals, maybe get a block hone, and you shoudl be ready to rock.
-PHiZ
Old Jan 6, 2004 | 07:15 AM
honura's Avatar
honura
Seni
Yeah man 300 now a days is cheap ! lol JK
Old Jan 9, 2004 | 12:31 AM
90tegLS703's Avatar
90tegLS703
thicker head gasket, port and polish the head, air and fuel ratio <-- important, check oil often<-- dont run too dry or too full, valves and springs upgrade, cams upgrade, port and polish intake manifold, upgrade throttle body 68mm should help, get s-afc, dsm 450 injectors, if on the budget dont touch the block yet.. once u start on that it's going to keep going.. with all that done run 7psi daily, 10psi on the track once in a while.. repeat once in a while, and dont try to rev too high.. keep it around 8500rpm <-- u kill ur engine faster that way on turbo unless it fully built to rev to 10k
Old Jan 9, 2004 | 10:29 PM
PHiZ's Avatar
PHiZ
BOOST GOD
OH yeah, also, don't listen to free advice on the internet cause every clueless dickwad feels free to levy their opinions.
-PHiZ
Old Jan 27, 2004 | 09:30 AM
pomansouth's Avatar
pomansouth
-PHiZ
werd. the gsr doesnt even rev that high and it has a upgraded oil supply and a block gurdle. it revs to like 8000, i forget the exact spec. it doesnt rev over 8 though.
