| Do It Yourself This is where you will find step by step instructions so you can Do it Yourself! |
Thread Tools | Display Modes |
#1 | |||||||
Just Hazin'
6th Gen Accord w/ 18's...Do i need a front AND rear camber kit?
| Sponsored Links | ||
#2 | |
Hot-Modder
Re: 6th Gen Accord w/ 18's...Do i need a front AND rear camber kit?
Quote:
optimum tire wear on 18's, good luck buddy, oh yeah, watch out for potholes
R.I.P. - - - '96 Civic 5spd EX Coupe. - - - We are the musicmakers and dreamers of dreams. Its you're ride, you've got to live with it, and at the end of the day, its your opinion that counts, not mine. |
#3 |
Just Hazin'
Gee sherlock, i know that 18s dont have as good tire wear. The bottom line is, if my tires are going to wear out fast, i want to get a set up that will give it the best possible wearing conditions.
#4 |
most of the time u just need front, because there front wheel drive and it would wear more, but if u can afford it i'd go with all around..hope that helped
jared terrell |
#5 |
with 6 gen accords.... it depends on your drop... if you get less then 1 inch drop, u probably don't need a camber kit but if you go more, you more likely need the rears b4 the fronts. i currently have H&R sports in my 6 gen with 18" with 48 offset and I only needed the Rears.. I drove around atleast 8000+ right now with no bad camber wear.. also I recommend Speicalty Product camber kits because they're the best..... Not cheap... and don't use the Washer method either, it don't work..
99 accord coupe v6 |
#6 |
Just Hazin'
How is the 48 offset? Is it rubbing at all? im planning to go a 45 offset and was wondering if i should go with a 45 or 48...lmk
#7 |
48 offset is perfect... some say 45 is rubbing for them if you got the wrong drop with wrong offset but with mine, it's perfect flush with the fender.. no rub or anything.. i actually ordered 45 offset but 48's came in. IMO, 48 is better now since i have 48 offset
#8 |
Just Hazin'
hmm, thats weird, ive heard different things from different ppl. Im currently on a Tokico 1.5'' Sports drop and was pretty sure i was gonna need a 45 offset. Can anyone second on the 48 offset versus the 45???
02' Accord LX I-4 I/H/E/C/P, 5000k HID, Hyper ground, WW kit w/ mugen lip, 18's on Tokico suspension w/ TL-S rear sway and upper front strut bar (2) JL 10w3v2 (1) JL 12w3v2 (5) Alpine V12 Amplifiers powering 16 Boston Pro and Infinity Perfect speakers. 93' Del Sol S RIP
| Bookmarks |
| Thread Tools | |
| Display Modes | |
