Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 12-03-03, 03:36 AM   #1
teggen
noisy front axle
i hear a noise coming from the drivers side wheel of my 93 integra. it sounds like the aluminum plate behind the rotor is rubbing on the wheel. i can hear it when once i reach 20-25 mph. once i hit 50+, the rubbing noise is much faster. i replaced my cv boots and the noise is still there. could it be the bearings or that aluminum plate? (the plate is a little bent out of shape). please help!!!
      Registered and logged-in users don't see this ad!
Register your free account today.
teggen is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 01-09-04, 12:18 AM   #2
1995 B16A
1995 B16A's Avatar
Did you look to see if there is a rock or something stuck behind the dust sheild?? (the plate) Just hit it a few times lightly with a hammer, see if something pops out.... Are your brakes goin bad????????????? check the warning tab on the pads...
David Neu
neud@pluto.dsu.edu
1995 B16A is offline   Reply With Quote
Old 01-14-04, 07:33 PM   #3
forzracer
There is a steel plate behind your brake roter. ITs thin maybe 1/16'' I'm willing to bet when you changed your brakes or cv boot, or maybe even just rotated your tiers you bent the plate in. Its just a heat deflecter. Take a screw driver and pry it inbetween your roter and the heat deflecter tobend ther deflecter away from your roter. Just be careful not to score your roter.
forzracer is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
