Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 11-30-03, 12:27 AM   #1
CivicSiRacer
Honorary Moderator Alumni
CivicSiRacer's Avatar
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
2000 Honda Civic Si moonroof leaking.
My car has about 56,000 miles on it and in January 2002 it had the sunroof fixed under warrenty due to a recall on the sunroof squeaking.
All they did was put in a plastic tape/strip around the outside of the sunroof (against the paint). After that it started leaking into the courtesy light. Water collects in the gutter towards the front of the sunroof, which then (I think) leaks into the courtesy light and drips down into the holder underneath the e-brake handle.
Anyone know what to do?
      Registered and logged-in users don't see this ad!
Register your free account today.
Autocross Help Page
CivicSiRacer is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 12-04-03, 12:15 AM   #2
illicon2003
Send a message via AIM to illicon2003
take it back and demand new parts..or a new car
illicon2003 is offline   Reply With Quote
Old 12-04-03, 12:38 AM   #3
CivicSiRacer
Well I can't since the service was performed 2 years ago.
Autocross Help Page
Old 07-27-05, 04:25 PM   #4
blndsoccer
A little late of reply but...
Sunroof leaks...there are drain holes in the sunroof, two in the front in the corners, and two in the back. I have an integra and had the same problem, it is becasue after a while the drain holes get plugged. Use an air compressor, or straightened clothes hanger to clean the drain holes. The front ones drain right behind your front wheel wells, Then the rears drain behind your rear whell wells. You can't get to the rear ones from the sunroof, but if you take off your rear bumper...there are several ways, you should find rubber hose type things that poke out from the body of your car. Stick a clothes hanger up those, and twist around, but be kina careful, just in case. When I did this water began flowing like niagra falls, it was amazing...no more leaky leaky.
blndsoccer is offline   Reply With Quote
Old 08-01-05, 12:44 PM   #5
hondatech
Honda tech/eprom hackr
hondatech's Avatar
Send a message via Yahoo to hondatech
I wouldn't use a coat hanger, just blow a little compressed air in the holes and you should be good to go
"Yes sir, your next service will be the
60k/transmission replacement"
"Ever wonder why the ppl with the least amount of technical knowledge get to tell the ppl with the most amount of knowledge what to do?"
hondatech is offline   Reply With Quote
Old 08-01-05, 06:14 PM   #6
S4gunn
Quote:
If you need a little longer reach than a coat hanger can give you, Walmart sells plastic covered solid wire to use as clothesline in the hardware section. I think I bought 50' for <$3. To be extra safe, just wrap the tip with some softer tape so that there are no sharp tips to snag/tear the drain hoses.
-g
2002 Audi S4
1992 Honda Accord LX (commuter car)
S4gunn is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
