| Do It Yourself This is where you will find step by step instructions so you can Do it Yourself! |
Thread Tools | Display Modes |
#1 | |||||||
1996 Civic 4 door sedan
| Sponsored Links | ||
#2 |
Try posting this in the 92+ civic forum. Someone there could probably help.
#3 | |
Stage 3 Modified
okay it sounds like to me that the driver side bulb is fried since both the high and low beams are not working,..if you are POSITIVE that the bulbs are fine then check your fuses,...if the fuses are fine then check the harnesses,..if the harnesses look fine then you got some wires to trace
Quote:
![]() State Trooper: do you know how fast you were going? Me: No not really,..my speedometer only reads up to 140mph and i was going way faster than that
#4 |
thanks for your suggestions
| Bookmarks |
| Thread Tools | |
| Display Modes | |
