| Do It Yourself This is where you will find step by step instructions so you can Do it Yourself! |
Thread Tools | Display Modes |
#1 | |||||||
DIY: Waterlogged Tail Light Fix
| Sponsored Links | ||
#2 |
first, you need material to make a new gasket. i know you can buy them, but why spend dollars, when you only have to spend cents.
i found two good materials. first, cheap mouse pads. the cheaper and stiffer, the better. wal-mart's most generic will set you back about $2. all you need to do is peel off the thin cloth cover. second, a sheet of craft foam from the craft dept. of wal-mart. it's not as thick, but is only 33 cents a sheet, and is more similar in texture to the original gasket. |
#3 |
comparing thickness...
mouse pad |
#4 |
...foam sheet.
#5 |
the mouse pad's cloth cover is easy to peel away, and leaves little, if any, glue residue.
#6 |
using the material of your choice, and use the old gasket as a template. a regular pencil makes a visible mark on the dark foam.
#7 |
make sure you mark the location of the holes.
this is where i was wishing i owned a hole-punch. |
#8 |
not bad...
#9 |
and now i have 2 new gaskets for approximately 16.5 cents each. and it only takes a few minutes.
cheers! |
#10 | |
forever lurking
nice tip
dealers
Quote:
#11 |
I would suggest just reusing the old gaskets along with some silicone..........
#12 |
Black CD5 Sedan
Nice write up...
#13 |
Damn man, thats a smart idea.
Just because you drive a Honda, don't make you Fast & Furious. |
#14 |
but what if you got water and like green crap in there? I know you can dump the water out...but i haven't figured a way out to get the crap off the inside of the lense. the lense is to brittle to try to pull apart from the rest of it.
mods: ls swap, hasport mounts, intake, header, full exhaust, rear sedan door handles, dei alarm with remote door locks, relocated optima battery, no ps or ac, skunk2 coilovers, 17 inch rims, wings west sides, opium front, extreme rear, custom painted tails, jdm corners, 95 gsr center console, 92 teg steering wheel, 2 12" mtx 8000 subs and mtx 6500D amp, body work and paint coming soon. |
#15 | |
Quote:
or you could just leave the water in there, and put in a few small fish and a snail or two, and have your own little mobile ecosystem!
| Bookmarks |
| Thread Tools | |
| Display Modes | |
