Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 10-28-03, 10:24 PM   #1
bigbrother?
Newbie needs help
Someone tried to steal my car and bent the steering column. I had the dealer replace it. When I picked up the car, the steering wheel was turned slightly and the steering was too tight. I took it back and they redid the spring. Now the wheel is turned more then the first time. I took it back to the dealer and was told that "the alignment must be off because the steering wheel can only go on one way". With my hands off the steering wheel the car tracks straight and I know that the alignment was perfect prior to the work being done.
Any help you can give will be greatly appreciated.
      Registered and logged-in users don't see this ad!
Register your free account today.
bigbrother? is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-30-03, 11:09 AM   #2
h22avid
Sleeper...Creeper...
h22avid's Avatar
My car is alligned but the steering wheel is turned to the right. the wheel being turned does not affect the allignment but it has everything to do with the allignment if that makes sence....
When a car gets alligned they are supposed to set the wheel straight and prop it there with a rod which holds it straight while the car is being alligned.
You can still allign the car with the wheel turned and be perfectly fine... it's more of an appearance issue than a performance issue.... but to get your wheel straight again, you will have to have an allignment done while the wheel is in the straight position.
H22Avid - monster tach with no GO is just SHOW!!!
h22avid is offline   Reply With Quote
Old 11-02-03, 12:45 PM   #3
hondatech
Honda tech/eprom hackr
hondatech's Avatar
Send a message via Yahoo to hondatech
Sounds fishy to me, was the insurance company paying for the repair? if so, complain, complain anyways, if it wasn't off center before the repair, they need to fix it. Tell them you will go to the BAR and complain if they do not fix it. Please post the name of the dealership so we can avoid them like the plague.
"Yes sir, your next service will be the
60k/transmission replacement"
"Ever wonder why the ppl with the least amount of technical knowledge get to tell the ppl with the most amount of knowledge what to do?"
hondatech is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
