Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 10-22-03, 04:51 AM   #1
cbrian3
Twisting Steering Wheel - how 2 fix?
The glue on the steering wheel has seem to worn away after years of heat. What I mean is if I am holding the top of the wheel I can twist it back and forth. Is there any type of a glue that they sell that can be injected into it to fix this problem?
Or- actually- can I buy a new steering wheel and be able to keep the airbag? Do they make aftermarket steering wheels that accomidate airbags- something sporty?
thanks for the help!
brian
      Registered and logged-in users don't see this ad!
Register your free account today.
cbrian3 is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-22-03, 12:16 PM   #2
h22avid
Sleeper...Creeper...
h22avid's Avatar
There's no way to fix that. Your grip on the steering wheel is actually just molded around a metal subframe via injection molding where they inject a hot liquid rubber into a mold where it cures and forms a hardened rubber grip around the wheel... there is no glue involved.
You would have to replace the wheel and the only way to retain the airbag is to go oem. You can however pick up one of the JDM OEM versions which look a little sportier than the USDM ones.
You can always pick up a huge serenge somewhere and try to inject some sort of polyurethane, or glue or something but that would be a fabricated process and not too sure how successful you would be.
H22Avid - monster tach with no GO is just SHOW!!!
h22avid is offline   Reply With Quote
Old 10-27-03, 06:47 PM   #3
SOHKeg
SOHKeg's Avatar
Send a message via AIM to SOHKeg
i got the same problem, i just deal w/it until my jdm steering wheel comes in
SOHKeg is offline   Reply With Quote
Old 09-12-08, 02:17 PM   #4
SCoupe
Yes!!!, There IS A Fix To This Problem
I read this thread in hopes of finding a solution to find only na-sayers. I am happy to report that: Yes, there is a fix to this problem !! I will preface this with the comment that my existing 16 year old VX steering wheel was as bad as they come. I was commited to buying a replacement but found the search for one difficult.
Figuring there was no possible way to screw this steering wheel up any more than it already was I went about a fix. Gorilla Glue, an 1/8" drill bit, some electrical tape fixed it back to a like new grip.
Remove the steering wheel (covered elsewhere), drill holes into the back side of the wheel that faces the cluster (out of site) spaced about every 3" or so. I did this around the top half of the wheel where it was loose, about six small holes Worked some water to into the holes as called for by Gorella Glue. Stuffed the tip of the Gorilla Glue into the hole and forced an appropriate amount of glue in each hole, wiped any excess with "Goof-off" solvent. (don't go overboard with shooting too much glue into each hole). I quickly wrapped the hole with electrical tape to seal the hole while the glue set. Twist the grip around to work the glue into the grip and spread it out. Let it sit over night.
Success in the morning, oh yeah!! The wheel was solid now, I removed the tape, the little holes are undetectible and the glue locked up the grip like new. There are no buldges or irregularities.
Ask yourself "what do I have to loose"? Answer: Not much. I'm damn near certain that you'll come out smiling at the end for this $5 solution to a common vexxing problem !
This will work
SCoupe is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
