Ask a Professional Detailer...
I dont want to sound like a dumbass but do HAN members get discounts when buying from you guys, reason I ask is im looking into buying like $380 worth of stuff from you guys and any discount will help
Registered
Thank you for your interest! If you have any questions what-so-ever, please do not hesitate to ask.
Sincerely,
George @ Detailed Image
Registered
Lighter cars definately are tougher to make pop than darker cars, but with the proper combination of products and techniques, it definately is possible.
What products are you using now Nelson? I'll see if I can fine tune that specifically for white (lighter) colored cars.
Registered
Originally Posted by MuleS2K
What's the best way to clean and protect a convertible's top?
My favorite combo for canvas tops are:
303 Fabric Cleaner - Clean up existing stains and prep the surface for the protectant. This product has many benefits. 1) It's a concentrated formula, so you can dillute it to the ratio that is needed to remove the stain. 2) It's a amazing all purpose cleaner for leather, vinyl, rubber, carpets, engine degreaser, and plastic. We usually use a 6:1 (water:303) mixture for most instances so that will make 6 x 32oz bottles = 192oz of cleaning solution.
303 High Tech Fabric Guard - This will help bead water and prevent stains from penetrating into the convertible top. Also works well on carpets and floor mats to prevent future staining.
Hope this helps, if you have any other questions, please do not hesitate to ask.
Sincerely,
Originally Posted by Detailed Image
First thing you want to do is wash and dry as normal then follow up with these two steps.
Sincerely,
Sincerely,
Registered
It depends what you are looking for in a tire shine. If its just durability then the stuff they use at dealerships will be what you want to invest your money in. They are silicone based tire dressings which are more durable, however they have many downsides. a) they sit on the surface rather than get absorbed into the tire, what this results in is excess product sling onto your paint which can be damaging since there is a high concentration of solvents in silicone based dressings b) they can damage your tires over time and lessen the life of them. They can cause that browning look on tires and definately is not safe for events such as autocrossing.
We strongly suggest a water based dressing that is safe for your tire because they get absorbed into the tire which results in little to no sling. They give it more of the new tire look rather than the wet glossy shine. They are not damaging to the paint or tires.
Our popular ones are Poorboy's Bold 'n Bright and 303 Aerospace Protectant.
Hope this helps your decision.
