Thread Tools | Display Modes |
#1 | |||||||
b18a swap
| Sponsored Links | ||
#2 |
HC Racer H5
best and cheapest b series motor mounts...look on www.thepartstrader.com for used ones and other boards
since you have a dx with dpfi...it'll be more complicated b/c of the wiring...you can buy a wiring conversion kit from hasport
04 Acura TSX (wife's car) 99 Chevrolet Silverado LT (gas guzzler) 89 944S2 (daily driver) 89 Honda ITA Honda Civic (go kart) [SIGPIC][/SIGPIC] |
#3 |
I'm RICK JAMES, bitch!
What? I thought B18 was more expensive than B16. But I rather have B18 cuz of the Torque.
http://www.fourthgenhatch.com FOR SALE! I need money for my new car! -HKS Sport Catback $250, pick up -JDM 90-91 Taillights $125. -Rear Disc Swap $300, comes with SS lines front and rear, 3 mon old rotors+pads, and 1 yr old calipers. |
#4 |
b18a is DOHV non-vtec, i'd love a 16 but as i said ... loot
jaje, you rule ... thanks. looking now. I'm right though that i need the axels and ECU also? I read stock integra mounts might work on mine, any way withoout a welder? oops, edited the wrong one Last edited by irresponsibleki; 07-12-02 at 11:10 PM. |
#5 |
is this the right one? sounds the closest to mine ...
"88-91 DX to Si or ZC $ 199 Converts DX, LX, and STD dual point injection to port injection" or is it the other one "DX to SiR Conversion Harness Use this harness in your DX to convert the dual point injection to port injection and also add all the necessary parts for use with DOHC VTEC engines. This harness is designed to be used with the PR3 and PW0 ECU. The harness is two parts, a complete engine harness and a sub-harness from engine to ECU. Price $249 with exchange of your DX engine harness " ? is that worth it? That's a lot of change for a wiring harness, i think ... Last edited by irresponsibleki; 07-12-02 at 11:09 PM. |
#6 |
The $199 one should be the right one, it's the DPFI to MPFI swap.
#7 |
dx to sir conversion is for a multiport with VTEC
integra mounts.. you probably heard that with the hasport mounts, you need the rear engine bracket from an integra. |
#8 |
HC Racer H5
the 1st one is just to upgrade to mpfi from dpfi (dx)...this is for non vtec engines (but easy to just add the 4 vtec activation wires)
the 2nd one adds vtec wires and converts to mpfi from dpfi (dx) the b18a is non vtec so you only need the $199 one...you can do the wiring yourself but it's a pain in the butt http://hybrid2.honda-perf.org/tech/4gdxtozc.html http://hybrid2.honda-perf.org/tech/4gtech.html
#9 |
ok, i THINK i could do the wiring myself if i go by that guide ... my dad's worried the shiftlinkage sounds like a hard job, and i just wanna make sure before i commit to this guy that i know everything i need - i see people mention '89 axels in some places, will my '88s and his '90s both not work? Again, i have no welder or experience ... looking for guides, finding some info but no pics
#10 |
this looks like a good deal for the mounts and the linkage for $325
jdm****.com god the cussing rules on this board are WACK S H I T |
#11 | |
for that added pep
Quote:
Nick- AIM whacko17 88 civic hatch: totaled w/ 79,000 miles 95cx/GSR hybrid - parted 95EX/coupe LS turbo
#12 |
will the stock teg linkage work in my crx swap?
#13 | |
HC Racer H5
Quote:
i'd wait to make sure you get the linkage b/c of the package deal...or have the seller take a pic of the engine with a full shift linkage and/or other parts to come with it
#14 |
Ok, question. How hard is it to install a B18b1 from a 94 integra ls into a crx hf. I Really like this engine, and was wondering if it was harder to install than a b16. Plus I can get one for cheap as crap. I know the b18c1's are kinda a pain since there are clearence problems, but what about the b18b1. Any info would be cool.
1991 Red Honda CRX HF - Dohc Zc With some stuff 1994 Acura Integra LS - Daily beater |
#15 |
not hard at all... i'm not sure about clearance issues with the hood. but it shouldn't be hard
#16 | |
HC Racer H5
Quote:
the b18b or b18a do not have a problem...they are about as tall as a b16a and fit in there easily...with the hf you know you'll have to change the front knuckle/hub/spindles b/c they only accept the small puny hf axles
| Bookmarks |
| Thread Tools | |
| Display Modes | |
