10-29-09, 06:10 PM
89 CRX si, now with b16!
Axle problem?
Hey here's my setup:
89 crx si
b16a swap
99 Civic si knuckles(for bigger brakes)
90 integra w/ abs axles (they're shorter than the axles w/out abs, so they fit)
Now, i've always hated how my tires had positive camber after I put on the 99 civic knuckles on(long story), so I finally found a 90 civic ex and took the knuckles from it. The passenger side went on just fine, but the driver's side is being a pita. What's happening is the axle is a bit too long, so when the wheel is turned right, the axle can't move(rotate), but moves just fine when turned to the left.. wtf? Now I thought maybe its the axle, so I went with 90 integra axles w/out abs, but those are even longer and make the wheel even more difficult to rotate..???
Anyway, what I think it may be is that I need to swap the intermediate axle out, since i'm using the one that came with my swap(from hmotors) for a 90 integra as well. Correct me if i'm wrong here, someone chime in for help cuz I need to get this fixed.
89 Honda CRX si
b16a swap - CAI, tein lowering springs, big brake upgrade, 16s  Coming soon: T3 Turbo
00 Firebird Trans-Am
