Fuel pump going bad? What are symptoms?
Old 07-18-2006, 03:56 PM
redcivicforever
redcivicforever's Avatar
(Keep in mind these symtoms are intermittently happening to my 91 civic hatch dx 1.5, and have been for a while now)
Would fuel pump that is going bad cause the car to jerk (like you didn't know how to drive stick) as you were trying to accellerate in 1st gear? Would it cause surging in accelleration or the feeling of not getting gas when you step on the gas in 1st gear taking off from a stop? It doesn't get any rev at all sometimes when I am taking of from a light even when I would expect I'm giving it enough gas to rev but then it will slowly accelerate like I'm barely giving it gas but I'm giving it sufficient gas. Could this be a TPS issue or maybe Air Intake issue that would cause these symtoms? Or something else maybe? Super appreciate any help you can give me this is driving me nuts.
Old 07-18-2006, 04:51 PM
m735is
m735is's Avatar
You'll have to measure the fuel pressure and you could rig it so you can watch it while driving (up between the hood and windshield, not inside)
Old 07-18-2006, 05:14 PM
Exempt
2 tone Rex
Exempt's Avatar
Sounds more like a slipping clutch too me...
Old 08-01-2006, 09:51 PM
crxtrafast
crxtrafast's Avatar
check your rotor and then change your fuel filter i did it to my crx after having the same problems and it helped that part anyways!
Old 08-02-2006, 12:33 AM
RevengeCRX
89 CRX si, now with b16!
RevengeCRX's Avatar
Sounds like a combination of tps sensor and a slipping clutch.
Old 08-04-2006, 10:37 AM
redcivicforever
OK thanks guys, BUT is there any way for me to know for sure OR be pretty sure, if it's either TPS or a fuel pump going bad? or possibly a fuel injector that's clogged or going bad? Anything that differentialtes one from the other or test that will differentiate to eliminate one or the other, narrow it down. If not then what would you guys do in my situation? TPS has come up alot as well as the other things I mentioned so has clutch but I'm less wanting to think it might be the clutch since it was just replaced about 8 months ago.
Old 08-04-2006, 09:04 PM
Exempt
2 tone Rex
Exempt's Avatar
Clutchs depend on both how it was installed (was the flywheel resurfaced is the main player and if it was PROPERLY broken in), and ofcourse the driver...
To test for this:
Put on the ebrake.
Start the car with the clutch in.
Put it in 4th gear.
Slowly let up while pressing the gas.
If the car doesnt stall, then its probably the clutch...
You can diagnose most of the other problems with a Helms and a volt meter...
Old 08-04-2006, 10:12 PM
samatronz_182
idiot.
samatronz_182's Avatar
wouldnt a bad tps sensor throw a code?
samatronz_182
idiot.
i would check pressures
Old 08-12-2006, 01:21 PM
redcivicforever
To test for this:
Put on the ebrake.
Put it in 4th gear.
Thanks finally someone tells me how to check the possibilities! Awesome thanks again!
