How can you tell if your piston rings are bad?
Old 11-02-2005, 03:54 AM
RedlineBoyzCRX
EG6
RedlineBoyzCRX's Avatar
Default How can you tell if your piston rings are bad?
I get alot of smoke at higher RPM's. Would this be my piston rings. If so how and where can I test it to find out?
Old 11-02-2005, 04:56 AM
Mixelplix
Mixelplix's Avatar
Do, or have someone do a compression test for you. It's simple to do, if you have the tool.
That will tell you that either your rings, or valves are bad. Or both.
Of you're blowing blue smoke at high RPM's, I would assume it's rings.
-Des!
Old 11-02-2005, 05:54 AM
Lude-Smakt
Banned
Lude-Smakt's Avatar
yea buy a compression tester. then you have to unscrew each sparkplug, one at a time and insert the compression tester firmly in the plug socket and have someone turn the ignition for you
Old 11-02-2005, 08:13 AM
teg92
WHAT OK YEAH!
teg92's Avatar
compression or a leak down test
Old 11-02-2005, 10:00 AM
Provocateur
On permanent hiatus
Provocateur's Avatar
Yes. A compression test won't tell you the whole story. For the problem, you need a leakdown test. If the pressure is leaking past the rings, you will be able to hear it coming out of the block.
Old 11-02-2005, 11:49 AM
RevengeCRX
89 CRX si, now with b16!
RevengeCRX's Avatar
With most 1st gen b16s i believe the piston rings get old by sitting there so damn long. So I would say yes, at high rpms a cloud of smoke indicates piston ring failure.
Old 11-04-2005, 03:59 AM
RedlineBoyzCRX
EG6
Well, I took out all my spark plugs last night, and they have the light brown color to them. Indicating that it is not to rich or too lean. But the Number 1 cylinder has some oil on it. I think it migh be from when it dripped in the bottom of the plug from the head, but would that indicate that my piston rings are messed up in the number 1 cylinder?
Old 11-04-2005, 05:02 AM
jdmeg6hatchy
i
jdmeg6hatchy's Avatar
on the ball as usual!
Old 11-04-2005, 05:04 AM
jdmeg6hatchy
i
if you were to replace them, I would do them all
Old 11-04-2005, 08:19 AM
teg92
WHAT OK YEAH!
teg92's Avatar
Oil on a spark plug does not mean your piston rings are bad. Do a Leakdown test and that will let you know if your rings are bad
