99 TL...very strange
ok,so about a week ago my A/C stops working..not stops blowing just stops blowing cold air..the heater stopped as well..still blows..just not heat..as far as the A/C the compressor kicks on..all the relays are good..full of refridgerant
just wont blow cold air..im at a loss...then today my ABS lights comes on..a few minutes later the TCS light comes on...and only have headlights on bright...any ideas what kinda gremlin i have inside this thing...car still runs great
well, took it to the Acura dealership yesterday...seems a rodent had chewed through the wire going to the A/C coil clutch...they want 560 dollars to fix it...the mechanic told me that the dealer makes them replace the whole coil and harness,but all i have to do is splice the wire back....spent a few hours working on it..took forever to get to the wire then there is no hand room to work, finally got it fixed and i have cold air now...the dim bulbs are both blown, gonna cost me like 365 to have them replaced,but at least i have cold air again
Interestingly, Honda now sells a Rodent Proof Tape to wrap around wiring harnesses. Apparently recyclable wire insulation tastes good! (But is it good for you?)
Here's a discussion:
http://tinyurl.com/2al4dsg
