Alternator life on 99 3.2 TL
Old 09-28-2009, 05:03 AM
ker
ker's Avatar
Default Alternator life on 99 3.2 TL
What is the expected/reasonable/average alternator life on a 99 3.2 TL? How difficult is it to replace the alternator and what should, I guess a rebuilt one cost? Thanks.
Old 10-20-2009, 07:37 PM
CARAMILK
CARAMILK's Avatar
Mine is still original at 175k, its pretty easy to replace. You'll need to go to autozone/pepboys and borrow their serpentine belt remover tool to loosen the tension on the alternator belt. Also when removing, remember to disconnect the power steering hose on the top to give enough room to take out the alternator. I just both the alternator and starter out this weekend to have them checked at Pep Boys to see which one was defective part. Turns out it was the starter which is cheaper to replace than the alternator. If your car is not starting, first have the battery checked, then the starter, than the alternator. Good luck.
Mauritius Hotels
coaching basketball
