diy distributor cap 97 acura tl
Old 11-28-2008, 06:53 PM
lmangus
lmangus's Avatar
Default diy distributor cap 97 acura tl
easiest way to replace distributor cap on 97 acura tl 2.5?
what wrench would enable me not to have to take battery and it's
shield out?
thanks.
Old 01-04-2009, 08:52 AM
dockyboy
dockyboy's Avatar
Default Replace Dist Cap 97 2.5 tl
I believe 10mm. its tough take out battery, make sure you have radio code, remove heat shield, hoses in your way,and a bracket that will let your hand fit in a little more easily, youll see the one on top. its a real PIA
good luck
