Air Conditioner blowing warm
Old 06-16-2008, 07:24 PM
boloughlin93
boloughlin93's Avatar
Default Air Conditioner blowing warm
I have a 04 TL and AC was working perfectly. I was idling for a while on the phone and when I shut it off and later that day I got in and the AC blows warm. It sounds like the compressor is kicking on. Any ideas or advice? Did I make something stick by idling so long? Are there any DYI for troubleshooting AC? Thanks.
Old 06-18-2008, 07:07 PM
tek54m
tek54m's Avatar
Look @ the front of A/C compressor while engine running and A/C on, is hub turning? Hub is in front of belt pulley. If not, other things to check. If yes, check to see if both cooling fans on radiator are on.
Old 07-10-2008, 06:12 PM
jaybirdoh
jaybirdoh's Avatar
Ok, what do you check if the clutch on the compressor is not kicking in?
