Won't shift out of park
Old 11-06-2007, 04:34 PM
MichAcura
MichAcura's Avatar
Default Won't shift out of park
I have a 1997 Acura CL3.0 160,K Today it wouldn't let me shift out of park and had to use the shiftlock over ride. I read a lot about the 99 and newer CL's tranny trouble now I am nervous. The manual states to bring it to an authorized acura dealership. (yeah, right) there are no other things going on with the car, just this little thing. (well, every now and then the A.B.S. light won't go off after startup.)
Has anybody else had this happen?
Old 11-07-2007, 04:50 AM
krevaughn06
krevaughn06's Avatar
sometimes if u wiggle ur key it the gear lock thing it will take care of it as far as the abs light check ur brake fluid that could be ur problem not enough brake fluid
Old 11-07-2007, 04:53 AM
Chiovnidca
SOHC Powered
Chiovnidca's Avatar
Do the brake lights work? Does the horn work?
Old 11-07-2007, 02:30 PM
MichAcura
MichAcura's Avatar
Default Silly Me
Found the problem with the car not wanting to shift out of park. This morning I also noticed that I had no brakel lights. I happen to hit the horn button while looking at the brake switch under the dash. I noticed the horn did not blow, so I looked at the owners manual and found the brake lights and horn are together. I blew a fuse, changed the fuse and Viola, shifts out of park again.
Last edited by MichAcura; 11-07-2007 at 02:51 PM. Reason: wrong word= brake lights not tail lights
Old 11-07-2007, 06:55 PM
Chiovnidca
SOHC Powered
Chiovnidca's Avatar
Keep an eye on it. Fuses dont usually pop for no reason.
Old 02-08-2008, 02:18 PM
bdr702
bdr702's Avatar
Default Shift Release
Look in your owners manual for a section dealing with SHIFT RELEASE.
If you follow the directions, you should be able to shift your gears.
They also recommend you take your car in for service as soon as possible.
