2005 pilot
Do You Have A Wiring Diagram/ Schematic For A 2005 Pilot Ex
yeap check uptop. make sure you get a bypass module for the transponder bypass and also, tkae your time and test your wires.
MECP Certified
Alarm/Car audio wiz
do you have the wiring diagram for an acura rsx 2003 premium it's the one without the bose system
for sure bud, if you need instructions how to remove the radio if you plan to upgrade feel free to ask. may i ask wheat you are planning to do? audio or security/remote starts?
MECP Certified
Alarm/Car audio wiz
For the wiring diagram for the acura rsx 2003 premium,we want to replace for another deck,but we need the code of the color,where can I find that please.
its at the top of the page, look for RSX and it will be there. Radio pin out and wire colours all labeled. I suggest you spend 12bucks and get a radio harness. if you live in canada like i do, head to a canadian tire and grab their wiring harnesses they are $9.99. this will save you the hassle of cutting wires and making mistakes.
MECP Certified
Alarm/Car audio wiz
if you could i need the 1990 honda accord ex wiring diagram for auto stereo system. thax
look at any of the accords under 1998, the wiring pinout is all the same.
MECP Certified
Alarm/Car audio wiz
bose amplifier/2004 acura mdx
i located the bose amp for the sub and center channel but i wold like to install line output converters to catch a clean signal after the fac. amp. i am installing a 4 ch. amp for the hi and a amp for a prefab box... any help would be greatly appr.
Originally Posted by
Tedmond
hey, here you go. from now on, i will post both audiovox and scytek diagrams as one so those that are unsure can cross referance their wires and make sure which is correct.
http://www.4shared.com/file/31819435...rd_4_Door.html
just a note to you h23sirlude, the door trigger wire is:
BLACK/WHITE (-) located @ DRIVERS KICK PANEL. usually it will be easily seen, if not, it will be in a gray plug, high up in the dash area. Always test with a DMM (digital volt meter) do not use test lights !!
I need the wiring diagram for a 1992 honda accord Lx for the alarm and keyless entry....thank
hey you got the audio wiring diagram for a 2002 acura 1.7 el?
Anybody have any horn wire diagram for a 2000 civic si?
2001 Honda Accord EX
Wondering if you have the audio wiring diagram for a 2001 Honda Accord EX with the 6-CD changer?
Anybody have wiring diagram for 2003 Acura MDX navigation and entertainment system? Trying to upgrade my car. Would appreciate any help
wiring harness diagram
say i need one for a 98 tl .
hey trying to install subs in trunk and a pioneer head unit but i need diy help and diagrams if possible i found a couple diagrams but for other models i have an 07 civic si sedan with the premium audio system wondering wat to do help me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Need 1991 Civic Ex Wiring Diagram
Any chance you have a wiring diagram for a 1991 civic ex?
I need to find out how to re-connect the instrument dimmer switch that has no plug on it. It has three wires coming out of the harness, but no plug.
Thanks...
Links go to 4shared and require some kinda desktop software?
Dunno if I want to install some desktop software to get the wiring diagram for a 1991 civic ex.
Any other way to get this file?
Thanks...
Where's the link to download the file? I need help with alarm and have others questions in general..
wiring diagram link gone?
Hello Tedmond,
I just joined the forum, and was looking for an '08 Accord EX-L Nav I4 wiring diagram. The link for the download appears to be broken.
Please let me know if I am doing something wrong.
Thanks!
Tedmond
hey mods, i was wondering if you can actaully create a special thread for me. If people want diagrams, what i will do is save them as a PDF and you can make a download section, and those that need diagrams can refer to this thread, look for their car year and model and just click to download. There is another topic aboud diagrams but its impossible to understand. If those that need diagrams can PM and i will update them fairly quickly. Well to let yall know i have diagrams to ALL car makes, year, and models. that includes trucks, suvs, and some bikes. I can guide you in alarm installs and audio system installs.
here are some quick links of requests so far. They will be in order Model then Year.
**If your car is LX and it shows EX, it will still have the same colours, just no factory alarm**
** Also Navi are the same same cars without the Navigation, so dont hesitate.**
- ACCORD -
1994 Honda Accord EX
http://www.4shared.com/file/33496616...da_Accord.html
1996 Honda Accord EX
1998 Honda Accord EX
http://www.4shared.com/file/35043856..._Sedan_DX.html
2000 Honda Accord EX
http://www.4shared.com/file/39888159...da_Accord.html
2003 Honda Accord EX Navi
http://www.4shared.com/file/31674702...avigation.html
2005 Honda Accord EX 6-Disk
http://www.4shared.com/file/32518147...Accord_Ex.html
2007 Honda Accord EX Navi
http://www.4shared.com/file/36218926...da_Accord.html
2008 Honda Accord Sedan
http://www.4shared.com/file/35043879...ord_Sedan.html
- CIVIC -
1992 Honda Civic DX
http://www.4shared.com/file/35043752..._Civic_DX.html
2000 Honda Civic EX
http://www.4shared.com/file/34684078...nda_Civic.html
2001 Honda Civic DX
http://www.4shared.com/file/32734039..._Civic_Dx.html
2007 Honda Civic SI Navi
http://www.4shared.com/file/34596603...nda_Civic.html
- INTEGRA -
1996 Acura Integra
http://www.4shared.com/file/28805204...a_Integra.html
- PILOT -
2005 Honda Pilot EX
http://www.4shared.com/file/38017353...nda_Pilot.html
- RSX -
2003 Acura RSX Premium No BOSE
http://www.4shared.com/file/39888311...a_RSX_20L.html
I got a 2000 4 door civic dx sadan and just installed a alpine in my ride and had to cut the harnest myself and the haynes manual didnt have the specific wire diagram need to know if you have the audio diagram for it please
help
my car wont start srs problems,,,,,,,,,please help 93 civic
Tedmond
No Problem, if any1 got any questions or request, by all means, just ask.
Hi, I have a light problem on my Honda accord. I saw you had many wiring diagrams so wonder if you maybe have one for Honda accord?
I ever not been able to find one anywhere else.
The problem is that the park lights wont work, in any mode. I wounder if any of the relay don't work, if maybe it's broken, or maybe it doesn't get power at all. I could have tested it, but I don't know witch of the relay that I should look at. So maybe you got some diagram for the relay.
Thx so much
Hey,
It's great idea but I am busy...
Sorry
Hey!! i could really use your help!! i have a 2003 honda civic hybrid and an after market Sony Xplod mexbt-5000 head unit i need the wiring diagrams but i cant find them anywhere!! Please HELPP!! THANKS
i guess this is a dead end too. i'm looking for a wiring diagram for a 2008 honda accord ex-l v6 but the links do not work.
I need a wiring schematic for a 2003 Acura Rsx -S for alarm.
It says the link for the 2003 Acura RSX premium no bose is not valid .. ..
why i cann't open those link?
Very knowledgeable and informative blog.
Honda-Acura
Honda S2000
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Search Engine Friendly URLs by
vBSEO 3.5.2
Bookmarks
