Results 1 to 11 of 11
Thread: Oem cd player + oem acura cd changer
  1. #1
    早晨好, 先生們!™ 粉腸+ 春袋 evolution's Avatar
    Join Date
    Jun 1999
    Location
    Toronto
    Posts
    8,720
    My oem cd player broke in the s2. I get an E-00 code and Honda says it's dead, but my warranty just finished. I can still play the radio.
    If I hooked up my oem acura cd changer (from itr, red/alpine?) will it work?
    I don't want an aftermarket because I like the radio controls beside the steering wheel.
  2. #2
    Older Honda Fanatic SumAccordGuy94's Avatar
    Join Date
    Jul 2002
    Location
    Adirondacks of NY
    Posts
    3,154
    question 1 = No, the changer plugs are different, you would need a changer from newer model hondas/acuras with the blue rectangular plug.
    As for an aftermarket deck, you can very easily add an aftermarket one... and keep your dash controls. There are adapters available that wire to the controls and can either send an IR signal to the new deck or with certain decks (new alpines, some sony) the adapter plugs right into the rear of the new deck.
  3. #3
    Join Date
    Jul 2002
    Location
    Adirondacks of NY
    Posts
    3,154
    heres the adapters on crutchfield: http://www.crutchfield.com/S-bF59JuO...avf=Y&skipvs=T
    They can be found elsewhere for cheaper usually (ebay)
  4. #4
    Join Date
    Jun 1999
    Location
    Toronto
    Posts
    8,720
    Thanks!
  5. #5
    Join Date
    Jul 2002
    Location
    Adirondacks of NY
    Posts
    3,154
    Let me know what you do... if you end up going with a new Alpine, or another unit that can be directly connected to the wired remote adapter I wanna know how it works. Ive done one S2K with a Kenwood headunit and the optical remote adapter, worked really well, just had to hide the IR sender for the adapter behind the radio cover.
  6. #6
    Join Date
    Jun 1999
    Location
    Toronto
    Posts
    8,720
    Quote Originally Posted by SumAccordGuy94
    I ended up taking a deck off my friend's 03' AP1.
  7. #7
    Join Date
    Jul 2002
    Location
    Adirondacks of NY
    Posts
    3,154
    Quote Originally Posted by evolution
    WTF is that??
  8. #8
    Join Date
    Nov 2002
    Location
    Orlando, FL
    Posts
    1,975
    AP1 is the first gen S2000 chassi code.
    98 Adriatic Blue Integra LS Sedan
    01 Electron Blue Prelude Base
    00 Anthracite Metallic Civic EX
  9. #9
    Join Date
    Mar 2006
    Posts
    13
    On the subject of the steering wheel control:
    About a year ago my steering wheel control started malfunctioning. Hitting volume would change the track and vice versa. This is pretty erratic, sometimes it works and sometimes it does not. Is this most likely the buttons? Could I just buy a new piece and replace it?
    thanks
  10. #10
    Join Date
    Jul 2002
    Location
    Adirondacks of NY
    Posts
    3,154
    Yes, its just an issue with the buttons, they get dirty inside and do not function properly. You can pull the switch off and tear it down to clean the contacts, or pick-up a new/used switch assembly.
  11. #11
    Join Date
    Mar 2006
    Posts
    13
    thx, accordguy. I took it apart yesterday to see what its workings were. The little slider switches looked a little dirty but they had some kind of grease all over so I didn't want to wipe them clean and remove all the grease. Maybe I'll take some que tips to it tomorrow. Anyways it seems to be working better after a little disassembly and reconstruction (and no extra parts ).
    thanks again
  12. #11
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
