how hard can it be !!!
Old 02-22-2006, 09:25 AM
JLO
7M-GTE!!!! "U-BLOC BITCH"
JLO's Avatar
Default how hard can it be !!!
so i dont want to pay some douche $70 to install somthing i can just do myself......i have 1 two channel amp and a box with two 10's in it tell me if this is right.........wire from the battery goes to the amp......AV cable head unit goes to the amp......ground wire to the chasi.....speaker wire to the subs is this right .........does anyone have a link with pics or instructions to do what im doing ?????????
Old 02-22-2006, 10:44 AM
ya need a remote wire from the hu to the amp as well
Old 02-22-2006, 05:24 PM
totalimmortal
MalleusMaleficarum
totalimmortal's Avatar
Us "douches",excluding a few, know what were doing.
Old 02-22-2006, 05:53 PM
Misa
Pic Whore
Misa's Avatar
https://www.honda-acura.net/forums/s...p+installation
basically h:
VPUPPY
VPUPPY's Avatar
What kinda of car is this going into? Automatic or 5spd? Do you have an aftermarket head unit already?
Old 02-23-2006, 05:22 AM
JLO
JLO's Avatar
yeah the head unit is after market.....and its a 5 speed integra .....am i more of less right with what im supposed to do? how hard is it to set up the remote turn on?
Old 02-23-2006, 08:40 AM
totalimmortal
MalleusMaleficarum
You cant be "more or less right" when you install an amp, theres right and wrong. Theres a good bit more to it than what you've described. Proper ground wire length, proper grounding, length between battery and fuse block. Then the power and REM need to be on seperate sides of the car as opposed to the signal wire.
Old 02-23-2006, 08:47 AM
SumAccordGuy94
Older Honda Fanatic
SumAccordGuy94's Avatar
haha, if you're in doubt have someone do it. Ive seen some pretty scary "installs" in brand new cars... that eventually went up in smoke.
Old 02-23-2006, 12:18 PM
Phateless
S2K compatible
Phateless's Avatar
in all honesty, it's really not that hard. you basically have it right. it will either work, or it won't. or you'll shock yourself. just use some god-damned common sense, be careful, and you'll be fine. other tips like
run the power wire on one side and the RCA on the other (so you don't get interference)
you want an inline fuse (on the power wire) right next to the battery
you want your ground cable to be pretty short, VERY secure and connected to clean, unpainted metal of the chassis.
ground cable and power cable should be the same gauge.
have fun. here i'm reposting this so it shows up in the thread
Old 02-23-2006, 12:21 PM
Phateless
S2K compatible
Phateless's Avatar
by the way, your aftermarket headunit is already installed, or are you doing that part yourself as well?
