how do you think it will sound with....
7M-GTE!!!! "U-BLOC BITCH"
i just bought a new kenwood 1000w amp and four pioneer 6.5s and i have shityy mobile authority subs (2 10s) even though the subs are crap how good do u think the system will be?
whats the difference between max and rms?
Max, it is a number you should not even look at.
If the amplifier is two channels then there is no way to run all of those speakers. If your amplifier is 4 channels then you technically could run everything but you would be drastically shorting the life of your amp if you run the two subs in bridged setup and the front and rear speakers on the remaining two channels. If this is your only option I recommend you run the subs parrallel (one sub on each channel) and combine the left front and rear to one channel and the right front and rear to the other remaining channel. This setup should sound pretty good but another amp will make your system a lot easier and more stable for sure. Hope this helps, if you have any other ?'s please ask.
sub power
ok so all i am going to do is run the two 10's off the amp and just run the speakers off the deck .........although with the amp i have will the subs be powered enough .....and will the speakers be loud enough just running off the deck?
jimmy
jimmy
jimmy
jimmy
