A little problem - Circuit Breaker?
Old 12-14-2005, 03:22 PM
Hondaman
Black Pearl
Hondaman's Avatar
Default A little problem - Circuit Breaker?
I'm installing a system in my 01 GS-R. I ran 1/0 wire from the battery to the back of the car, but I'm having a hard time finding physical space for a fuse holder under the hood near the battery before it goes through the firewall. Normally I'm not a fan of circuit breakers for car audio installations, but I'm running out of ideas.
Here is my thought...
I put a 200 amp circuit breaker under the hood near the battery and at the end of the wire, in the trunk, where I have more space, I'll add a fuse holder with a 200 amp ANL fuse. This way my equipment will be protected by a fuse and if something should short in the wire from the front to the back, the circuit breaker should pop.
Any other thoughts? :dunno:
Old 12-18-2005, 05:01 PM
jragon
jragon's Avatar
Well actually DC voltage actually runs the opposite of what your stating. It is pulled up from the chassis to the amp and back to the battery through your 1/0 cable. If there is a problem with any of the wiring from the front to the back it will blow your fuse. Whatever you do definitly put an in-line fuse within 12 to18 inchs of the batt for your safety and the safety of your car. You don't want a bonFire especially with 1/0 cable.
