1999 accord v6 or 4cyl how to manualy read abs codes
Old 11-09-2012, 11:55 AM
carcrazeeeee
carcrazeeeee's Avatar
Default 1999 accord v6 or 4cyl how to manualy read abs codes
99 accord v6 or 4cyl. where is the manual abs connector located??
Old 11-10-2012, 05:13 PM
carcrazeeeee
136 views and no one can answer the question??? whats the deal???
Old 11-18-2012, 08:30 AM
carcrazeeeee
hello,anyone out there?????????????
Old 11-19-2012, 10:48 AM
94civicEX
I got worms.
94civicEX's Avatar
Your DLC connector should be located underneath the steering column on the left.
Originally Posted by ehudson
2 digit codes are usually from checking light flashes. Your code 67 is the same as a P0420 read with a scanner. It means "Catalyst system efficiency below threshold" This can sometimes be caused by a bad Catalytic converter or a problem with the O2 sensor located after the catalyst.
I found this list of codes elsewhere on the web. Maybe it will help...
__________________________________________________ ______________
For those of us who won't(can't) spend $$$ in OBD-ii scanners; there is an alternative to find out
about codes and that CHECK ENGINE light that is driving us crazy:
1) Go to Autozone and have them read your codes (it's free)
or
2) See the instructions below
WARNING!!!: USE AT YOUR OWN RISK.
HOW TO OBTAIN TROUBLE CODES MANUALLY (6Th Gen Accord - V6 & I4)
1) Find the Data Link Connector (DLC) located under the instrument panel in the driver's side.
2) Jump terminals 8 and 13 by connecting them with a wire/cable.
...............________
...._____|________|_____
.../|1...2...3...4...5...6...7...8|
./..|9.10.11.12.13.14.15.16|..
DATA LINK CONNECTOR (DLC)
3) Turn the ignition key to ON and observe the "CHECK ENGINE" light. It will flash the trouble codes. For example: 2
long flashes, pause and then 3 short flashes = 23 = P0325 = Knock sensor circuit fault.
One short flash = 1. One long flash = 10. If there is no trouble codes, the light will not flash.
Flashes.....Code(s)............................... ..........Description
1...............P0131,P0132....................... .........Primary heated O2 sensor circuit low/high voltage
3...............P0107,P0108....................... .........Manifold Absolute Pressure (MAP) sensor circuit low/high voltage
4.............. P0335,P0336.................................Cranks haft position sensor
5.............. P1128,P1129.................................Map sensor circuit low/high voltage
6...............P0117,P0118....................... .........Electronic Coolant Temperature (ECT) sensor circuit low/high input
7...............P0122,P0123,P1121,P1122........... Throttle position sensor (TPS) circuit low/high input
8...............P1359,P1361,P1362................. ....CKP/TDC sensor 1
9...............P1381,P1382....................... .........CYP Sensor
10.............P0112,P0113........................ ........Intake Air Temperature (IAT) sensor circuit low/high input
12.............P1491,P1498........................ ........EGR valve
13.............P1106,P1107,P1108.................. ...Barometric pressure sensor
14.............P0505,P1519........................ .........IAC valve
17.............P0500.............................. ..............VSS fault
20.............P1297,P1298........................ .........Electric Load Detector (ELD)
21.............P1253.............................. ..............VTEC
22.............P1257,P1258,P1259.................. ....VTEC
23.............P0325.............................. ..............Knock sensor
41.............P0135,P1166,P1167.................. ....Primary heated O2 sensor
45.............P0171,P0172........................ .........System adaptive fuel too lean/rich
48.............P1162.............................. ..............Primary heated O2 sensor
58.............P1366,P1367........................ .........TDC sensor 2
61.............P0133,P1149,P1163,64,65............ Primary heated O2 sensor
63.............P0137,38,39........................ ...........Secondary heated O2 sensor
65.............P0141.............................. ...............Secondary heated O2 sensor
67.............P0420.............................. ...............Catalyst system efficiency below threshold
70.............P0715,20,25,30,40,53,58,63......... .Automatic transaxle malfunction
71.............P0300,P0301........................ ..........Random/Cylinder 1 misfire
72.............P0302.............................. ...............Cylinder 2 misfire
73.............P0303.............................. ...............Cylinder 3 misfire
74.............P0304.............................. ...............Cylinder 4 misfire
75.............P0305.............................. ...............Cylinder 5 misfire
76.............P0306.............................. ...............Cylinder 6 misfire
80.............P0401.............................. ...............EGR insufficient flow
86.............P0116.............................. ...............Electronic Coolant Temperature (ECT) sensor range/performance
90.............P1453,P1457........................ ..........EVAP control system leak
91.............P0452,P0453........................ ..........EVAP fuel tank pressure sensor low/high input
The codes that will not flash are as follows (will need code scanner):
P1607-PCM internal circuit failure and
P1705,06,38,39,53,68,73,91-Automatic transaxle failure
HOW TO CLEAR TROUBLE CODES (after fixing problem)
1) Remove ignition key (OFF)
2) Locate fuse panel on passenger's side (open door)
2) Remove fuse no. 13 (7.5 amp) for 10 seconds, and then place it back in.
I hope this info helps you, as much as it helped me.
Enjoy!
99 Integra GSR
06 TSX
duck squad member #00003
Old 11-24-2012, 11:32 AM
carcrazeeeee
im not asking for the check engine light codes,or how to read them, i know how to do that!!! i need ABS CODES????????? how to manually read ABS CODES!!!!!!!!!!!!!! CAN ANYONE HELP?????
Old 11-25-2012, 12:16 PM
carcrazeeeee
hello, is there anyone out there????? can anyone help or is this site just a joke????
Old 11-25-2012, 10:46 PM
mcsurui
mcsurui's Avatar
Is not a joke.
Old 11-25-2012, 11:47 PM
carcrazeeeee
ok, well for some reason i cant get any answers??? what do i have to do???
Old 11-26-2012, 03:54 PM
94civicEX
I got worms.
94civicEX's Avatar
Patience is a virtue. Continually bumping the post isn't likely to help.
Regarding the ABS codes, you short the DLC and read the flashes from the ABS light, not the CEL.
ABS Codes
1 The hydraulic pump motor is over-run
1-2 The hydraulic pump motor
1-3 Is a high pressure leak
1-4 The pressure switch
1-8 Accumulator of high pressure system
2-1 Circuit of handbrake warning lamp switch
3-1 Rotor teeth damaged on right hand front wheel speed sensor
3-2 Rotor teeth damaged on left hand front wheel speed sensor
3-4 Rotor teeth damaged on right hand rear wheel speed sensor
3-8 Rotor teeth damaged on left hand rear wheel speed sensor
3-12 Combination of different sizes of tires
4-1 Circuit of right hand front wheel speed sensor
4-2 Circuit of left hand front wheel speed sensor
4-4 Circuit of right hand rear wheel speed sensor
4-8 Circuit of left hand rear wheel speed sensor
5-4 Right hand rear wheel lock
5-8 Left hand rear wheel lock
6-1 Front fail safe relay
6-4 Rear fail safe relay
7-1 Right hand front, hydraulic modulator solenoid valve
7-2 Left hand front, hydraulic modulator solenoid valve
7-4 Rear, hydraulic modulator solenoid valve
8-1 Operation of the ABS
8-2 The ECU
8-4 Internal circuit of the ECU
99 Integra GSR
06 TSX
Old 11-26-2012, 05:17 PM
carcrazeeeee
ok, thank u very much!! what 2 connections on the dlc need to be connected to read the abs codes??
