oil pan gasket if exhaust is welded.
Old 03-24-2012, 11:23 AM
OSPF
OSPF's Avatar
Default oil pan gasket if exhaust is welded.
Everything from where the A pipe connects to the cat and back is entirely welded on by the previous owner. What's the best way to approach this? If I undo the first set of hinges that hold the exhaust up will it come down far enough so I can remove the oil pan? The welds look kind of brittle don't want anything to crack and cause a bigger problem. Car is a 92 accord.
