Results 1 to 6 of 6
Thread: 1998 Honda Accord Coupe 4 cyl Auto Odd Issue... Need ideas.
  1. #1
    Junior Member heyfunny's Avatar
    Join Date
    Dec 2008
    Location
    IA
    Posts
    14
    I have been having this odd issue lately that once the car is warmed up and then shut off for a little while then drove a few miles more shut off again it will turn over but not start.
    While having the issue it also will not let me change out of Park not even to neutral.
    While having the issue all the electronics work as far as radio, lights, dash, windows etc.
    The car will usually start again on the first crank like it was nothing but only after shutting it off and waiting 3 - 45 minutes randomly
    It also never sputters or tries to shut off while I am driving.
    So far..... Since I got the car this has been done...
    New Timing Chain / Water Pump
    New right rear wheel Bearing
    New Coolant hoses
    New Radiator Cap
    New Battery
    New Belts
    New Vtec Gasket & Screen (All other Vtec Parts Checked out fine)
    Oil Change, Air Filter, Oil Filter (Full Synthetic High Mileage) every 3000 mi.
    New Plugs (NGK) and Wires
    New Cap & Rotor
    New Front HO2 Sensor
    New Cat Conv.
    New Transmission (Not Used, 100% Rebuilt w/2 yr warranty) ($3250) yikes!
    New Starter
    New Ignition Switch
    New Valve Cover Gasket
    Need some ideas on what the issue could be.
    Boss is getting very pissed and I don't know what the problem could be.
    Thanks in advance for the help.
    1998 Honda Accord EX Coupe V4 AT ^_^
  2. #2
    Join Date
    Aug 2011
    Location
    Pittsburgh, PA
    Posts
    20
    best guess is you Honda needs an alternator. car can start off the battery, but without the alternator to keep recharging it, you're not going anywhere
  3. #3
    Join Date
    Dec 2008
    Location
    IA
    Posts
    14
    Quote Originally Posted by mwatters View Post
    Thought of that, My battery is charging fully and has still had the issue at full charge. Although sometimes turning it over for a half hour will drain it before too long.
  4. #4
    Join Date
    Apr 2011
    Location
    Upland, CA
    Posts
    20
    Quote Originally Posted by heyfunny View Post
    New Coolant hoses
    New Radiator Cap
    New Battery
    New Belts
    New Cap & Rotor
    New Cat Conv.
    New Starter
    New Ignition Switch
  5. #5
    Join Date
    Apr 2011
    Location
    Upland, CA
    Posts
    20
    Even thou U have a 98 Honda...This was a common problem on the first 90--94 hondas.
    Master Relay switch...The conditions are simular, hopefully the result is too.
  6. #6
    Join Date
    Jun 2012
    Location
    mineostta
    Posts
    3
    usually when you cannot take the car out of park it is the safety switch on the brake pedal assembly. When that switch goes bad, it is just like trying to take it out of park without depressing the brake pedal. Look under the dash on the brake pedal arm, should be a small button that is depressed when the pedal is not being pushed.
    The other issue sounds like the ignition switch.
  7. #6
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
