Power Steering Issue or Rack and Pinion '05 Accord
Old 02-11-2012, 11:18 AM
IslandGirl7
IslandGirl7's Avatar
Default Power Steering Issue or Rack and Pinion '05 Accord
Recently changed the PS Pump, engine emanating high pitched noise at warm up and intermittently throughout the day, could it be the Rack & Pinion??? Or something else, what do you think??
Old 02-22-2012, 01:52 PM
cruzalekz
cruzalekz's Avatar
check belts, also re check that you have enough ps fluid after the last install
Old 03-09-2012, 06:38 PM
robbiebravo50
robbiebravo50's Avatar
Hey IslandGirl7....Just checkin BUT are u aware that Honda p/s pumps take
ONLY Honda p/s pump fluid. Any other will corrode the system.
My next assement would be if he sound is being emmitted from the ac
clutch... when the belt is loose and or dirt and debris in the ac clutch will make a
high shrill noise. Generally hear it when the car first starts and is cold.
Old 03-14-2012, 09:52 AM
Jessicas
Jessicas's Avatar
check the belts and enough fuel is there are not.
