V6 EGR Valve
Old 06-09-2003, 10:02 PM
SumAccordGuy94
Older Honda Fanatic
SumAccordGuy94's Avatar
Default V6 EGR Valve
What exactly goes wrong with these in the j30 motors? My Acuras check engine light is on, and the code comes up for "EGR valve, insufficent flow". It is covered under warranty by acura, but I can never get the car down to the dealer, and a Honda dealer wont fix the problem for me.
Is there something that can be done with it? I know its right on the top of the motor, and pretty easy to get to... but what would I have to do to the damn thing to get it working properly again?
I'm asking here, cause I know certain accord V6s had the same problem.
Old 06-10-2003, 03:10 PM
honda guy
honda guy's Avatar
Basically the EGR valve is replaced also the intake manifold is removed because the port gets clogged with carbon. Once its removed we have a special drill bit to enlarge the port and then there is a special sleeve that we insert. And that is about it.
Old 06-10-2003, 03:15 PM
98CoupeV6
lots and lots of fail
98CoupeV6's Avatar
EGR is a common problem. Mine blew at 40k, the dealer got Honda to reimburse the expenses.
Search button would help you.
