Transmission Problem P0700
My Honda Accord 2002 2.3lt V4 started with transmission problems a little over a year ago. When cold, the card would hard shift into 2 & 3rd. After a while, say 5 minutes of driving and changing gear all gears changed fine.
Initially I took it to a technician who ended up putting in a new master rebuild kit. When the car left the shop it still had the same problem just changes weren’t as hard as they used to be. I ended up taking it to the trany shop 3 more times over the following 3 months with no positive results. I continued to drive the car this way, and I would let the car warm up 10 minutes before I left and this seemed to help for a while. As time progressed the symptoms got a little worse. The reverse started to shift hard also, and every once and a while (usually when I didn’t warm up the car long enough) the hard shifting would make D4 start flashing and the gears wouldn’t engage and I would have to turn of the car, change to Park, turn on the car and back to D4.
So finally I decided to take it to another trany shop. They scanned the car and the following code came up:
P0700 FAULT IN TRANSMISSION CONTROL MODULE
P0739 3RD PRESSURE SWITCH
P0780 SWITCH MALFUNCTION
P1751 MECHANICAL FAUL IN HYDRAULIC SYSTEM
They said that the gears were burnt and that they had to put in another master rebuild kit and that the torque converter also had to be rebuilt. They went ahead and made the recommended repairs. After they completed the repairs the said that the car was still having the same issues as when I took it in. And it is still giving a P0700 error code (I asked if there were any other codes along with this one and they said the P0700 was the only error code). They said they swapped the solenoids a few other parts to see if that was the issue and that the car continued to present the same symptoms. They deduced that the computer was bad and that it had to be replaced. This is where I am at right now. I have a feel the once the computer is repairs I am still going to be left with the same problem.
Can anyone make any recommendations? A new computer is going to cost a fortune as it has to be programmed by a Honda dealer. I've looked online for something affordable but it always boils down to have to reprogram the computer at a dealer.
I am aware of the lawsuit and all considerations that Honda has given its car owners. But my car is out of warranty and it has 168K miles already. My transmission was repaired by Honda for similar issues at about 70k miles (I purchased the car at a Honda used car lot, so the engine and trany were cover under a 100k Honda certified vehicle warranty). Excuse all the incorrect terminology.
Only Cool Clothing Sites
Famous clothing travis barker Competition clothing Retail clothing rack Japanese winter clothing Pusch clothing calgary 1910 clothing styles Gothic era clothing Nba unk clothing Look clothing company Carlysle clothing
I found the navigation options to be vague and unhelpful, and it took a while to grow used to it.I would not have much patience with the navigation problems if I wasn't generally so pleased with the information in Acne No More, though. You might also try and take advice of established affiliate marketers so that you get first hand opinion and advice of these affiliate marketers on the same. Ultimately cost is matched to actual use and performance of the asset that is financing. Proper proununciation, good grammar and sound listening skills in Spanish do not come about by chance, so it will come as no surprise to you that the proper training, in the form of top shelf Spanish learning programs, is crucial. By this you people will pay you through putting their advertising website on your blog if you have a reliable and consistent traffic in your website on a daily basis.
Nellys clothing lines Richard teend clothing Barbour clothing new york Clothing consignment toronto Clothing g unit Coldcreek clothing Clothing large women uk Austin reed and womens clothing Clothing cotton plantation Jamaican clothing style
